Would it be possible to use a 4b11 engine head on a 4g63?
Old Jan 26, 2008 | 03:07 AM
chrsevx's Avatar
Old Jan 26, 2008 | 03:13 AM
whoang40's Avatar
why? what's the reasoning behind it?
Old Jan 26, 2008 | 03:18 AM
chrsevx's Avatar
Mivec.
Old Jan 26, 2008 | 03:43 AM
Jameson_IXMR's Avatar
It may very well be, but I would really have my doubts. But with enough fabrication, anything is possible.
Old Jan 26, 2008 | 11:04 PM
chrsevx's Avatar
Man, I hope it will be easy to do and cheap the additional help of mivec on a turbo would be insane for spool up.
Old Jan 26, 2008 | 11:06 PM
EvoDan2004's Avatar
you do realize there is a 2006 evo IX that has this right??
you have a better chance in getting the evo 9 head on an evo8 block then u do with that junk that comes on the X to fit onto the evo8
Old Jan 26, 2008 | 11:07 PM
bluebanana23's Avatar
yea but IX has mivec only on the intake side
Old Jan 26, 2008 | 11:17 PM
krazy srt4's Avatar
well the 4b11 if im not mistaken uses a timing chain and not belt so clearance is diffenent
Old Jan 27, 2008 | 01:27 AM
jdmevo8313's Avatar
Registered User
Is everyone forgetting the fact that the turbo now sits between the firewall and motor? A lot more work than just swapping the head since the cams and tranny sit the same way as previous evo's. Just my 2cents....
Old Jan 27, 2008 | 01:32 AM
alan678's Avatar
Mivec.
Actually the Evo X has both intake and exhaust MIVEC...
Old Jan 28, 2008 | 03:15 AM
BBS's Avatar
BBS
This is the most retarded idea possible. You do realize that the 4B and the 4G are reversed? Use your brain alittle bit before you post useless banter on the forums man. USELESS YOU ARE.
Old Jan 28, 2008 | 03:49 AM
supersal's Avatar
Isnt the 4B a Chrysler motor as opposed to a true blue 4G Mitsu Powerplant?
Old Jan 28, 2008 | 09:54 AM
KeithD's Avatar
Krazy srt4,
you are correct the X uses a timing chain
I don't know why some people waste our time with a stupid question like this. If you want intake and exhaust MIVEC then buy an Evo X. This idea is insane and would cost more money than it is worth. If you have that kind of money put it tward somingthing more useful that will make you more power. If you want more spool build a stroker.
Old Jan 28, 2008 | 09:57 AM
joseph k's Avatar
the 4b i think may be a chrysler motor
Old Jan 28, 2008 | 10:01 AM
joseph k's Avatar
all-alloy straight-4 engines built at Mitsubishi's Japanese "World Engine" powertrain plant in Shiga on the basis of the Global Engine Manufacturing Alliance (GEMA)
piponpi
Sep 9, 2016 07:33 PM
Alireza_MH
Lancer-Mirage Compatibility Forum
Sep 9, 2016 04:12 AM
sworddemon
Feb 13, 2013 07:49 PM
89LA
Lancer Engine Tech
10
Feb 16, 2010 11:11 AM
forgsix3wannab
Lancer Engine Tech
Mar 13, 2008 08:43 AM
