Car dies sometimes when going to neutral and slowing down to a stop?
Old Jan 27, 2008 | 08:16 PM
vboy425's Avatar
i bet you car when into lean idle. need to tune it to give more fuel when the throttle plate is shut. what type of ECU are u using ?
Old Jan 27, 2008 | 09:19 PM
omniprobe's Avatar
hks 280's and using aem ems
Old Jan 27, 2008 | 09:22 PM
huevosrancheros's Avatar
well that sucks, maybe you need a better tune sir.
Old Jan 28, 2008 | 11:40 PM
vboy425's Avatar
yep he definitely need a better. If you have a wide band. look at as you come the stop, you will see the AFR dip pass 14.7 like 15+ afr. car choke and stumble. the rpm drop and go back up. i have 272/272 using autornic. my idle AFR is 13.1. when i come to stop, i tune the ecu to give more gas so the AFR won't go pass 14.0 AFR. Now with 280/280 it even worst.
Old Apr 10, 2011 | 09:30 PM
gotspeed's Avatar
sorry to bring this up, but Im going through the same problem.
Hey OP did u even find out what causes it to die? anyone know?
Old Apr 10, 2011 | 10:08 PM
omniprobe's Avatar
Not sure. This was my old setup and it spun a bearing so I never got to fix the issue. I did have this issue on my new setup due the idle compensation which needed some fine tuning. This problem can be caused by a lot of stuff.
Old Apr 13, 2011 | 07:26 AM
EvO_vIII_McCoY's Avatar
I call the tune. My first tune kept dying shifting out of gear or coming to a stop. Eventually I called my tuner and had him look at it again. Problem fixed.
Old Apr 13, 2011 | 09:06 AM
Pirana's Avatar
I currently running into the same problem. Although mine only happens after a boosted run. In my case I'm going thru some of the mechanical setups first. I found out I have the unpainted Tial BOV spring and with 280 cams I have about 10in of vacuum. So I need the black spring. Of course this is causing the BOV not to open and cause compressor surge. This might be the problem or not. I'm waiting for the new spring. After that I would have to check the MAP sensor or the TB.
J Woody
Jan 11, 2014 07:02 PM
taylorgang
Dec 10, 2011 06:22 PM
Mirage2.0
Lancer Tranny/Drivetrain Tech
May 17, 2007 01:00 PM
lengvang
Dec 13, 2006 11:40 AM
Derek888
14
Jul 6, 2005 08:47 PM
