cams installed... engine dies out sometimes
Old Jul 6, 2005 | 06:13 PM
Derek888's Avatar
After I installed my 272's the rpm dips too low and the engine dies out. This only happens when I come to a stop from around 40mph or above when I let it cruise in neutral to a stop light(letting the rpm drop too fast). But when idling or driving around normaly it doesnt happen. Besides the cams I have the top head built, ported, racing valves etc.... Also the car has not never been tuned before so could this be the reason why its flaming out when coming to a rolling stop in neutral? Not sure why it only flames out when the rpm drops instantly, when coming to a stop while in gear it doesnt happen.
Old Jul 6, 2005 | 06:14 PM
en1gma19's Avatar
If it's not tuned for the cams, that's probably the reason.
Old Jul 6, 2005 | 06:15 PM
BoostWhore's Avatar
get it tuned it more than likely needs some more fuel and the idle raised up some
Old Jul 6, 2005 | 06:16 PM
Thegame's Avatar
It could also be your intake and VTA BOV if you have either, which I assume you do.
Old Jul 6, 2005 | 06:18 PM
EasyZ06's Avatar
If you just let the rpm's drop theirs no load on the motor, and with the new cams your car doesnt know how to compensate. Try downshifting for the time being that should keep it from stalling out, but you really do need to get a tune. You never want to run your car too lean and i wouldnt be suprised if you are with those cams. You could burn something up in your motor.
Good Luck
Jeff
Old Jul 6, 2005 | 07:27 PM
Derek888's Avatar
We did hook up a 02 sensor and the A/F is fine. Just want to make sure its normal that it does flame out when installing cams without a tune. Also my BOV never had a problem before so I dont think that is the reason its flaming out? I will get it tuned asap, thanks for the feedback.
Old Jul 6, 2005 | 07:33 PM
Warrtalon's Avatar
You hooked up an O2 sensor? You mean, in addition to the ones that are already on the car or what?
Anyway, I can't believe you've done cams and a rebuilt head, but have never been tuned. That's quite strange...
Old Jul 6, 2005 | 07:39 PM
Evoryder's Avatar
u got the AC on when u come to a stop?
Old Jul 6, 2005 | 07:42 PM
jxn evo 8's Avatar
when changing cams what other internal need to be changed also?
Old Jul 6, 2005 | 07:43 PM
Warrtalon's Avatar
None.
Old Jul 6, 2005 | 07:45 PM
jxn evo 8's Avatar
are cam gears needed or will the stock ones work just fine?
Old Jul 6, 2005 | 07:53 PM
Evoryder's Avatar
cam gears are not needed...but replacing the stock ones for a matching pari is a good thing...
i would do it.
Old Jul 6, 2005 | 08:17 PM
mifesto's Avatar
dude get a clue and wake up .... u answered your own question.... get it tuned and ask again. lol
Old Jul 6, 2005 | 08:35 PM
fre's Avatar
fre
I got tuned and my car still does it. Of course I have 660cc injectors, a bigger turbo, a lighter flywheel and a vta BOV that could all be contributing to the fun though. What happens with my car is that it floods comming to a stop and sometimes dies from too much fuel. Car has already been flashed and it didn't help, however it did make it run smoother on cold starts. Maybe the new ECUTek would do the trick. If i'm going to spend more money on engine management im going AEM though.
Old Jul 6, 2005 | 08:47 PM
Derek888's Avatar
Im not sure what he hooked it up to but it does look like it is the 02. I just got the car back yesterday, before that I only had a TBE.
BlackDismay
Dec 12, 2011 06:05 PM
TaiwanEvo
37
Jan 13, 2009 11:09 AM
Porsche518
Jan 27, 2005 08:57 PM
lemacfar
Jul 27, 2004 10:17 PM
Noize
Nov 23, 2003 12:31 AM
