No Top End Power
Old Jan 28, 2008 | 12:14 PM
PHIL_N_THE_EVO's Avatar
No Top End Power
I have a 2005 evo 8 with stock block, built head, and meth. After about 4500rpm my stock turbo seems like it falls flat on my face. It has a lot of torque but no top end. My dyno after the ems tune was 340whp/360ft lbs. Does anyone know what could cause this? I thought I might have to put this in the advanced threads but I am trying to see if anyone else has had this problem. If anyone knows about air volume that would probably be the most helpful.
Old Jan 28, 2008 | 12:19 PM
precisi0n's Avatar
Phil, meet stock turbo. Stock turbo, meet Phil. You need something bigger if you want topend. I think the stock turbo flows somewhere around 28-30 lbs per minute if that is what you are looking for...
Old Jan 28, 2008 | 12:25 PM
dxbevo9's Avatar
Old Jan 28, 2008 | 12:37 PM
I am about to put a GT35R but I was trying to find the reason why my setup didn't hold true while others with like setup's have the stock turbo hold up. I appreciate the air volume fact cause I just started to use the formula. From what I am seeing my built head doesn't have enough air when the 272's kick in. It is almost like I am choking it. Retorical I know.
Old Jan 28, 2008 | 12:39 PM
shivaswrath's Avatar
FP helps the top end a bit, but yes, the 35r is WOAH up top, ick down below, unless you go twin scroll. . .but take my advice with a grain, since I'm flirting with the stock turbo and dealing with the "choke" myself. . .
Old Jan 28, 2008 | 12:57 PM
SLOWRREX's Avatar
I had a similar problem with my car..It turned out that my upper intercooler hose was leaking,at the second clamp..And it only did it under full boost..Not sure if this helps any..But something you might check..Good luck either way..Justin
Old Jan 28, 2008 | 04:11 PM
My fix for the choke looks to be the ATP stealth 35r kit. Any testimonials/ objection?
Old Jan 28, 2008 | 04:14 PM
1slowevo's Avatar
go with a kit from someone else... you will be happier
Old Jan 28, 2008 | 05:17 PM
BOOSTEZ's Avatar
Let's see your dyno sheet to prove that it actually does fall flat on it's face.
My turbo holds strong all the way to redline. Do you have cams?
Old Jan 28, 2008 | 05:30 PM
RedLanEVO's Avatar
i dont know about you, but i got top end power!
just kidding man
Old Jan 28, 2008 | 05:31 PM
RedLanEVO's Avatar
i dont know absolutely anything about this...i was just taking up some space of my uselessness.. thanks
Old Jan 28, 2008 | 05:42 PM
BOOSTEZ's Avatar
Well stop spamming with silly pix.. if anything post up a pic of a hot chic!
Old Jan 28, 2008 | 05:46 PM
RedLanEVO's Avatar
hahaha...ok well i dont have any
u might have a head gasket leak dude (small leak from cylinder to cylinder or something like that), either that or you are burning oil. check your oil after a couple hundred miles. if not, i dont knoe what else!
Old Jan 28, 2008 | 05:49 PM
Tarmacisback69's Avatar
atp= junk, their cheap for a reason
Old Jan 28, 2008 | 05:59 PM
mitdrx's Avatar
Have you considered a 50 trim?
