Boost Problem?
Old Jan 28, 2008 | 03:44 PM
vxevolutionxv's Avatar
Boost Problem?
I just installed my AEM Tru Boost, INjen UIC pipe and Injen intake system today and went for a test drive. when my boost level got to approximatly 15 psi it droped off approximatly 3-4 psi and then went back up to 15 and kept doing this. It thought it was the vacum lines where expanding and letting pressure out of the ends but i put better clamps on them and it still occured. if anyone could throw sum suggestions my way it would be greatly appreciated! Thanks!
Old Jan 28, 2008 | 08:18 PM
you guys r a real help...............
Old Jan 28, 2008 | 08:30 PM
sparky's Avatar
We are notoriously lethargic on Mondays.
Old Jan 28, 2008 | 08:34 PM
EVOlution561's Avatar
hahahahha
Old Jan 28, 2008 | 08:46 PM
sparky's Avatar
I am not familiar with the AEM TrueBoost. Is that a gauge and EBC combined? How did you hook it up? Are you switching over from the stock BCS setup? Supposing that your controller is properly routed, then you might try raising the WG preload by shortening the actuator rod two turns. Then again, your boost controller may be improperly installed.
Old Jan 28, 2008 | 09:56 PM
chaotichoax's Avatar
did you reuse the stock boost lines? if so you failed
are you sure you hooked it up correctly? (right hoses to right places)
did you play with the settings on the boost controller?
you gave us limited information and you want specific answers
what does this look like a holiday inn?
Old Jan 30, 2008 | 03:58 PM
LOL I have it hooked up correctly and yes I've played with the settings I turned the boost to20 psi. but what r u talking about the stock boost lines what does that matter. I also have a xheck engine code its sumthing to do with the EGR valve I believe, could that be causeing my problem? cause I have no clue what the EGR valve is? Sorry about posting on a monday LOL now I know better. hehe
Old Jan 30, 2008 | 05:01 PM
sparky's Avatar
You say that you have the boost controller properly hooked up, but did you use the stock boost/vacuum hoses, or did you remove the factory hoses and the boost control solenoid and connect your controller up with new hose?
You can't reuse the factory lines because they contain a couple of internal resrictor orifices.
Old Jan 30, 2008 | 05:06 PM
rele... cause that be causing the fluxiation in boost after I hit 15 psi tho? cause factory boost is more than 15. I'll try replacing all my vacum hoses thanks for the sugestion I'll try that tomorrow and post back. I just fixed the EGR valve it blew a hose off and its still doing it so it cant b the egr valve. any other sugestions would b nice.
Old Jan 30, 2008 | 05:10 PM
one more thought tho I read the egr vacum hoses blowing off could foul plugs, could a fouled plug be causing this?
Old Jan 30, 2008 | 05:13 PM
sparky's Avatar
Yeah, try it! Use 3/16"(4mm) hose and zip ties on each connection. Remove the factory vacuum hose assembly and store it as a unit, for if you ever need to go back to the stock configuration. The BCS has to be out of the equation as well, that is, disconnect it's hoses but leave the electrical connector plugged into it.
Old Jan 30, 2008 | 05:15 PM
gabeamaro's Avatar
spell check is your friend and you installed all that and havent had a tune?
Old Jan 30, 2008 | 05:18 PM
ok cool thanks my stock boost controller is still electrically connected so yea I'll try that and I'll get back to u. thanks again.
Old Jan 30, 2008 | 05:21 PM
for your info I just installed it and was having this problem so butt out if u don't have + input!
Old Jan 31, 2008 | 01:25 PM
I found the problem. it was my wastegate duty% was set to high, I'm a retard lol. thatnks for your suggestions tho.
