Cam Gears
Old Jan 29, 2008 | 06:40 PM
TKEVO's Avatar
Veteran: Air Force
Cam Gears
Is Cam gears worth the money or no? If so, besides the HKS which other brands are good quality or does it matter?
Old Jan 29, 2008 | 08:17 PM
Nomad4g63's Avatar
its all based on timing
usually when u upgrade camshafts you should upgrade
cam gears
timing belt
arp headstuds
and if you plan on keep building your motor
springs and retainers
even tho on some camshafts there is no need to do it, if you plan on beefing up the motor your going to need to do it sooner or later, so why not do everything all at once that way u dont need to take off the head or remove the valve cover more than once
Old Jan 29, 2008 | 08:21 PM
RevMoto's Avatar
please if you are going to give help give some that he can use. No you do not need to get a new timing belt. Also you do not need headstuds. That is a myth. Especially not needed for what he is going to be running.
Old Jan 29, 2008 | 08:42 PM
wshihdnevo's Avatar
^very true alot of people are running all of the above w/ out doing a timing belt and head studs. Same things w/ rod bolts too. You can, but dont have too. Do your timing belt if its time to do it, not b/c you are doing these upgrades.
Old Jan 29, 2008 | 10:02 PM
Aby@MIL.SPEC's Avatar
your going to hear a bunch of stuff regarding cam gears.....
yeah, people can make decent power with oem cam gears...but can they make more power in a specific area with cam gears, 90% of the time yes...
beleive it or not, oem cams @ -4/-4 or -5/-5 pulls pretty damn good.
i like the aem cam gears, 5 large bolts. i have hks, they are ok, difficult to read due to color of lines & blue hubs.
Old Jan 30, 2008 | 06:13 AM
TKEVO's Avatar
Veteran: Air Force
Ok so I don't need to change the timing belt cause I was looking into that. I will start another thread about APR headstuds cause I keep getting both to change or not to change my headstuds. I will list the mods and stuff I plan to have on my car.
Old Jan 30, 2008 | 06:29 AM
brokeazzlos's Avatar
I have a set of AEM tru-time cam gears for evo8
silver with the 5 bolt design 175 shipped
Old Jan 30, 2008 | 10:00 AM
TKEVO's Avatar
Veteran: Air Force
pmd
Old Jan 31, 2008 | 06:26 AM
pmd back!
Old Jan 31, 2008 | 07:13 AM
thanks
Old Jan 31, 2008 | 07:24 AM
TKEVO's Avatar
Veteran: Air Force
This is gay. My computer isnt bringing these pics up
hutch959
10
Nov 25, 2016 05:35 PM
dillons13
Oct 10, 2016 10:52 AM
badev0
Feb 17, 2016 01:28 PM
sheepy77
Oct 28, 2015 01:45 PM
MacMan
28
Dec 14, 2014 05:22 AM
