Evo 9 Spark Plug List, Also how to read plugs.
Old Mar 23, 2013 | 06:11 PM
  #196
Migsubishi's Avatar
The Denso IKH24 are great plugs, they are doing what they need to in my car. We will be tuning for 25psi + here shortly. Will report back then.
Old Apr 17, 2013 | 01:00 PM
  #197
Floseph's Avatar
Putting the NGK ILFR7H Laser Iridium plugs in my EvoIX this weekend. Been long over due for a change!
I also checked the Gap on them and they came gapped at .021 all 4 of them.
Old Apr 17, 2013 | 02:53 PM
  #198
Migsubishi's Avatar
Denso IKH24 are great plugs! perfect for high power!
Old May 5, 2013 | 11:50 PM
  #199
aamoedo's Avatar
How are people measuring the gap and gapping plugs without touching the electrode? Are they really as sensitive as the Denso website makes them out to be?
Old May 6, 2013 | 07:20 AM
  #200
Migsubishi's Avatar
I put the ground strap on a counter top or solid bench. Then I lightly tap the top of the plug to bend the strap and close the gap to where I need it.
I use feeler gauges to measure mine, I set them to .018 .457mm
Old May 6, 2013 | 08:14 AM
  #201
aamoedo's Avatar
Thanks. I figure a very slight tap with a hammer and eyeballing with a feeler gauge will probably get the job done, without actually having to touch the electrode. Just curious to see what other people had done.
Old May 6, 2013 | 08:46 AM
  #202
evo8426's Avatar
I use pressure on a solid surface to close the strap. I would be a little weary of tapping it with anything.
Old Jul 14, 2013 | 05:35 PM
  #203
mrowka's Avatar
From: Driving ten under in the passing lane, right turn signal on at all times.
OK, dump question/thread resurrect:
Basically stock IX, Ebay exhaust and LICP, will add a DP soon, 23 psi, conservative tune. In other words, stock heat range ought to work best, am I right?
Just checking.
Old Jul 19, 2013 | 02:51 PM
  #204
b00st3d.'s Avatar
Does AutoZone, O'Reilly's, or advanced carry EVO 9 plugs? I'm basically stock power level. So the ikh22s are best? Which ngk plugs are stock equivalent?
Old Jun 26, 2014 | 01:11 AM
  #205
EvoTurboTurk's Avatar
Can someone list evo 9 plugs? I don't own a evo 9, but I want to avoid accidentally purchasing plugs recommended for a 9 & it won't end up fitting my evo 7. Are BPR9EiX, BPR9ES, BPR8EiX, BPR8ES for a evo 9?
Old Jun 26, 2014 | 05:46 AM
  #206
Faisalm's Avatar
Evo 7/8:
Iridium:
Stock heat range:
NGK - BPR7EIX
Denso - IW22
NGK - BR7EIX
1 step colder:
NGK - BPR8EIX
Denso - IW24
NGK - BR8EIX
Copper:
Stock heat range:
NGK - BPR7ES
Denso - W22EPR-U
NGK - BR7ES
Denso - W22ESR-U
1 step colder:
NGK - BPR8ES
Denso - W24EPR-U
NGK - BR8ES
Denso - W24ESR-U
Evo 9:
Stock heat range:
NGK - ILFR7H
NGK - LFR7AIX
Denso - IKH22
1 step colder:
NGK - R7437-8
Denso - IKH24
Old Jun 26, 2014 | 11:14 PM
  #207
Originally Posted by Faisalm
Evo 7/8:
Iridium:
Stock heat range:
NGK - BPR7EIX
Denso - IW22
NGK - BR7EIX
1 step colder:
NGK - BPR8EIX
Denso - IW24
NGK - BR8EIX
Copper:
Stock heat range:
NGK - BPR7ES
Denso - W22EPR-U
NGK - BR7ES
Denso - W22ESR-U
1 step colder:
NGK - BPR8ES
Denso - W24EPR-U
NGK - BR8ES
Denso - W24ESR-U
Evo 9:
Stock heat range:
NGK - ILFR7H
NGK - LFR7AIX
Denso - IKH22
1 step colder:
NGK - R7437-8
Denso - IKH24
?BPR9EiX?
Old Nov 22, 2014 | 11:52 PM
  #208
evoiao's Avatar
what spark plug would be recommended for Evo9
with 513 whp all bolt ons, spool in up cop, 25g turbo, 272 cams, larger &0mm Tb, ported Intake mani, tub exhaust mani, cat delete, peak boost 30psi and running on E85
densos.....which one? stock, or 1 step or 2 steps colder. Californian car, always good E85 available.
Old Mar 19, 2015 | 10:50 AM
  #209
600RR's Avatar
Just checking.
Originally Posted by EvoAlex666
I have an Evo IX with a turbo back exhaust, intake, and ic piping. Basic bolt ons. What would you guys recommend on brand/gap?
Originally Posted by rich3389
Whats the deal with the Denso IKH24? I have an IX with basic mods, TBE, intake, looking to get tuned to around 25 PSI approximately 330-350 WHP. Should I get the Denso 1 step colder or stock NGK?
I just ordered these, will let you know Saturday how they turn out.
Can any of you respond to how things worked out for you? Which plugs did you go with?
I'm in need of some. I have basic bolt-ons 330 whp @26 psi.
Old Mar 19, 2015 | 01:50 PM
  #210
evo8426's Avatar
No reason to run anything cooler than the OEM plug. NGK ILFR7H is what I use on stock turbo and 500whp+ setups.
