Intake manifold testing.
Old Mar 11, 2008 | 04:34 PM
  #496
Evo8Emperor's Avatar
If I may i need to ask a question that does pertain to intake manifolds. and testing to if it'll help me get an answer. lol.
But I was wondering what the placement is on the map sensor on the intake manifolds. Or do you need other means of a map censor from a stand alone ?
Old Mar 11, 2008 | 04:47 PM
  #497
crcain's Avatar
Originally Posted by davidbuschur
I am not testing the JMF. I've seen the video, looks interesting, not testing it.
The JUN is what is being tested next with a 3" throttle body. I may end up putting the Kansai and Driven back on the car with 3" throttle bodies to see how they do too.
I just want to figure out which one is the best and leave it on my car.
Not that you probably care too much Dave but when I asked Simon Norris about the difference between the HKS and the JUN he said mainly it was that the HKS lost a little bit down low while the JUN did not.
Old Mar 11, 2008 | 05:03 PM
  #498
David Buschur's Avatar
crcain, I spoke to Simon too. That is why I am testing the JUN
Old Mar 11, 2008 | 05:15 PM
  #499
9sec9's Avatar
David, it's amazing how the results you posted concerning the manifolds and the FMIC's correlated to what we saw with a much smaller turbo. It looks like your data was good across the range. For those didn't see our results with the DI, in a nutshell our AFR's went up by 2.5 to 2.6 from 5000 up. That was even with a larger meth injector. Ran the 680's out of duty cycle. Your stats proved dead-on when compared to what we have observed. Now, get those 780s to us.
Old Mar 11, 2008 | 05:41 PM
  #500
2k4EvoVIII's Avatar
If one of you has a new intake manifold I'd be more that willing to put it on my car and test it. I actually am going to do further testing as soon as I get in the JUN intake manifold anyway.
I'd like to test the new intake from Magnus and actually see it increase power.
You have a PM sir!
Old Mar 11, 2008 | 05:50 PM
  #501
PM answered.
Old Mar 11, 2008 | 05:53 PM
  #502
vwjeff's Avatar
DAMN Tom
Tonys car might break a mid to low 10 this year on a green
Old Mar 11, 2008 | 06:00 PM
  #503
Could anyone point me in the right direction atleast as to where i could find that out?
I was wondering what you had to do to run a aftermarket manifold concerning the map censor. and whether or not you have to run a stand alone.
Old Mar 11, 2008 | 06:12 PM
  #504
9sec9's Avatar
I drilled the TB plate and mounted the JDM map sensor there. The material was about 3/4 " and I used a step bit and carefully tested the depth using the sensor as I went. Then drill and tapped the bolt holes. Logging today it worked perfectly. I use stock ecu and maf.
Old Mar 11, 2008 | 06:19 PM
  #505
Driven Innovations's Avatar
Evo8emperor you got PM regarding your question!
Old Mar 11, 2008 | 07:03 PM
  #506
9sec9 could you elaborate for me please what you mean by you throttle body plate ? What aftermarket manifold are you running and what TB ? If you dont mind me asking.
Old Mar 23, 2008 | 10:04 PM
  #507
Talonboost's Avatar
Wow, I didn't even know this was going on until I saw it in DSport today. (May 2008 issue - just came out). Really one of the best tech comparos in a while.
Thanks DB for doing all this testing and making it public!
Gary
Old Mar 24, 2008 | 06:42 AM
  #508
talonboost, it turned out to be a very well put together article. Glad you enjoyed it.
Old Mar 24, 2008 | 06:43 AM
  #509
Mellon Racing's Avatar
that's awesome that the data was published, good press for BR and EVOs
Old Mar 24, 2008 | 06:51 AM
  #510
Aby@MIL.SPEC's Avatar
place the map sensor in line with any runner within the plenum.
that is where the oem pressure differential sensor is located & why buschur & other companies make a map sensor block that bolts into the oem locatioit's placed in the right spot.
