windage tray / crank scraper?
Umm... I was wondering if the 4g64 guys usually transfer over the windage tray? And where could I get one?
I called a local dealership, and they said they could only get the oil pan, and not the windage tray. He said it was all one part. Could someone guide me in the right direction?
the oem thingy is just more of a baffle, not really a scraper.
cosworth makes a scraper, its ~$50-. i saw a pic posted, maybe on norcal evo. i thought the scraper would be closer to the rods & crank.
+1 on the cosworth, cant beat it for the money. We always have them in stock.
So, does the crank scraper replace, or get installed in addition to the windage tray?
And, how do I go about purchasing one from you nolimitmotorsports? is it easier for me to call or e-mail?
The Cosworth 4G63 Crankscraper is engineered to reduce parasitic drag on the crankshaft caused by oil accumulation that surrounds the crankshaft during rotation. This oil buildup causes additional drag and can reduce power output. Additionally, overall oil control is improved by keeping oil in the sump. Especially useful in high rpm and race applications, Mounts to main bearing girdle.
hmm interesting...i think i will be buying one sence we are building the car as we speak....and your right you cant go rong for 60$ shipped.....do you know if this would throw off the tq specs for the main studs??
No it doesnt mess up the tq specs, they wont even be touched to put this on. Let me know if you need one Mike, i got one here.
i will also be getting the valves to that we talked about!!
