What do you think about SeaFoam?
Old Feb 6, 2008 | 01:24 PM
ohEVO18's Avatar
i have wanted to do this, but i dont have the *****, i'll screw something up i know it...
Old Feb 6, 2008 | 06:49 PM
TwistedEvo8's Avatar
haha im going to try it on my friends 2g GSX First haha and ill let you guys know how it went hes got 98k miles on it so if anything we will see something out of it!
maybe ill get a video
Old Feb 10, 2008 | 02:07 PM
Synapse's Avatar
I was skeptical about it at first. I had a weird fuel miss at mid-range. Put seafoam in the fuel and the miss went away.
Old Feb 10, 2008 | 02:19 PM
yea we put it in the gsx and we ran it in the gas/Oil/ Vacuum line and put 1/4th the can in each place! The Vacuum line and gas tank did its job well! we put it in ran the car then shut it off! Let it sit for 30 min then started the car up and there was a lot of smoke and we looked on the floor and all we could see was little peace's of black specs (he has no cat only straight pipe) so all the junk came out and it worked wonders the car runs better and starts up a lot faster! Dont think i need to use it on the evo yet! Seems to run good enought maybe just in the fuel to help fuel injectors
Old Mar 30, 2008 | 09:32 PM
NewEvolutionIX's Avatar
Go to this web site and get what you need http://www.bgprod.com/products/engineoil.html
I went to a local car show out by me and they did some test to show us this BG product, using it for the transmission, oil, and gas. Just from watching there demonstration it looks way better than Seafoam! Check it out
Old Apr 18, 2008 | 02:34 PM
Solo II Evo's Avatar
Originally Posted by TwistedEvo8
yea im prob going to use it im going to switch from Mobil 1 to royal purple and before i change it im going to add it into the oil and let it do its work for a hour or so then drain and flush out the old oil with royal purple and then fill her up with royal purple and so all the sea foam will be gone! then run it in the gas tank... i dont know about running it into the intake... should i just run it through the vacume line untill i see smoke? or only add so much like 1/4th ? thanks
I"d question your reasoning for going to Royal Purple; if anything, do some reading on oil before switching brands.
Also, yea definitely run it through the brake booster and follow the instructions on the bottle. I haven't sprayed any in my intake manifold before, but I have used oil/brake booster/gas tank with good results.
Old Apr 18, 2008 | 09:58 PM
edit: I put some in the oil tonight and drove around a bit, changed the oil, and it really seemed to clean everything up well (oil looked a bit gritty)
Old Apr 19, 2008 | 05:36 AM
BURNALL_4's Avatar
Originally Posted by kaonashi
lol i use seafoam to remove bugs off my bumper and windsheild, We've used it in older cars but i wouldnt stick it in my car.
Just me ;/
Pump your brake, Hold on, slap that B!tc# in reverse.....What do you use it for? And are we talking about the same stuff.
Old Apr 19, 2008 | 05:58 AM
Azntoyhere's Avatar
Hey guys i have been using seafoam for my car every time i do an oil change. It is very very good and i recommend for you guys to try it. it helps out your engine a lot because you are eliminating all the dirty material and crap in your engine. Noticable difference once its put in.
Old Jun 17, 2008 | 05:28 PM
MasterAK's Avatar
Do I have to replace the spark plugs after running the seafoam through the vacuum hose?
Old Jun 17, 2008 | 09:11 PM
03Cobra2Evo's Avatar
seafoam awesome !
Old Jun 17, 2008 | 09:31 PM
LOL No you don't have to change the plugs after running sea foam. Would kinda defeat the point of seafoam if it did that!
Hotevo3
13
Oct 23, 2012 04:27 AM
NoClanSWAT
Lancer Engine Tech
Oct 9, 2012 09:10 AM
Seifer780
Lancer Engine Tech
Oct 27, 2011 01:14 PM
steven121
Lancer Engine Tech
11
Aug 9, 2011 11:05 AM
ODUB
Feb 10, 2011 08:07 AM
