9:1 Compression
Old Feb 8, 2008 | 06:13 PM
Ev0cRaZy's Avatar
9:1 Compression
My 2.3L comes in monday, its a 9:1 compression motor.
Crower Rods, Weisco Pistons.
What boost are people running with this higher compression on pump gas (93)
and Race (110octane)?
Those are the gases I will be tuning for.
Thank you.
Old Feb 8, 2008 | 06:27 PM
Jean's Avatar
22 psi on 93
Old Feb 8, 2008 | 06:28 PM
Ev0cRaZy's Avatar
Thanks Jean
Anyone know on Race?
30psi? Max?
Old Feb 8, 2008 | 07:12 PM
Jean's Avatar
Originally Posted by Ev0cRaZy
Thanks Jean
30psi? Max?
Sorry first post was vague.
I'm running 22 psi with a PT6776R and making over 500 on 93.
On race depending on the octane and how its tuned you should be able to go as high as the upper 30's on 118 for example.
Trying to just raise the boost and lowering timing to keep the engine from detonating is like fighting against your self. So its just a matter of finding a safe level on different octanes for you car. Also taking all the mods into consideration and finding a safe median for power and reliability.
Old Feb 8, 2008 | 07:16 PM
Ludikraut's Avatar
I would let my tuner decide that... i.e. if tuned properly, you'll figure out where your setup is making the most amount of power w/out detonation.
l8r)
Old Feb 9, 2008 | 12:33 PM
jezefink's Avatar
on pump dont go over 24psi...depending on injector setup and tuning...on meth/pump...32psi..and on straight race c16.....38,40..depending on your ring gaps...do u know what they are set at?
Old Feb 9, 2008 | 02:12 PM
Ev0cRaZy's Avatar
No sir. I could probably find out though.
Thanks for the post!
MercenaryX2
Aug 11, 2013 05:21 PM
mrm95
21
Jun 17, 2013 02:30 PM
browningderek
Oct 14, 2010 05:41 AM
apeximprt2nr
69
May 27, 2008 02:26 PM
lbcevo
Mar 13, 2006 04:29 AM
