drivetrain help
Old Feb 12, 2008 | 02:05 PM
blackep925's Avatar
oh yeah another thing...when i drive it in reverse it doesnt do that..it drives fine
Old Feb 12, 2008 | 02:57 PM
blackep925's Avatar
the car doesn't shake when the 4wheels are in teh air..so does that mean it has 2 do w/ something in the suspension?
Old Feb 12, 2008 | 05:44 PM
rolly1818's Avatar
Registered User
yeah might..... weird though......when u fix the problem let me know....
Old Feb 13, 2008 | 08:32 AM
ACTman's Avatar
This tells a lot. Chatter is basically the engine rocking back and forth in the mounts as the clutch is engaging. There are a few different causes, all related to clutch or engine mounts. If the chatter is clutch related it wouldn't matter if you are going forward or reverse. On the other hand, if it is related to mounts, it would act totally different depending on what direction you are going, just as you indicated.
Old Feb 13, 2008 | 09:02 AM
blackep925's Avatar
well i found out that the mount that is connected 2 the back of the tranny i didn't put the bottom bolt on so the motor rocks back in forth...so i'm ganna try 2 do that now and then i'll post up if it worked..thanx again
Old Feb 13, 2008 | 10:52 AM
blackep925's Avatar
ok well i just test drove the car again and it still kinda does it but not as bad..but only of i try 2 take off fast
Old Feb 13, 2008 | 11:11 AM
Mr. Evo IX's Avatar
Originally Posted by ODUB
+1 on how you adjust it because i HATE the engagement point on my Exedy stage 1 clutch. it's too high. i need it lower. everybody i've asked said that there's no way to adjust the engagement point, only the pedal. thanks
Adjusting the pedal does adjust the engagement point. If you increase the rod length it lowers the engagement point and pulls the clutch farther away from the flywheel.
Old Feb 14, 2008 | 09:29 PM
ODUB's Avatar
well is there a way to adjust the engagement point of the clutch without adjusting the pedal, like a bolt on the master cylinder as some have said? also, when you do adjust the pedal to get a lower engagement point you adjust the pedal closer to the driver, or farther away?
Old Feb 21, 2008 | 08:52 PM
CatalystIX's Avatar
+2, i would also like to know how to adjust the engagement point
Old Feb 22, 2008 | 09:04 AM
ACTman's Avatar
Check out this how-to thread:
https://www.evolutionm.net/forums/sh...d.php?t=260783
rodeo0808
Dec 15, 2011 04:01 PM
evodrivesme
24
Aug 14, 2010 05:51 AM
VRamirez2004
16
Oct 6, 2008 11:18 PM
blackep925
Feb 9, 2008 02:56 PM
v8killer
13
Oct 30, 2004 02:14 PM
