Extremely rough idle this morning
Old Feb 19, 2008 | 07:25 AM
sluflyer06's Avatar
Bump for the day crew.
Old Feb 19, 2008 | 11:26 AM
tvor's Avatar
no love? I have a sinking feeling that something is either already terribly wrong or it's about to go terribly wrong with my car.
Old Feb 19, 2008 | 11:31 AM
DS-03evo's Avatar
Do a boost leak check, and check your throttle body seals.
Old Feb 19, 2008 | 02:55 PM
tvor's Avatar
Yeah doing that on Thursday. It feels like it's almost running on three cylinders, it's shaking bad. I think I'm going to go park it for a couple days until I can check more.
Maybe I lost spark or fuel in one of my cylinders? How could I check the wires for spark and the injectors to make sure one didn't close or fail?
Also, Would any of this be symptematic of one of my Cam gears Skipping a tooth on startup? That's the only other thing I can think of. Since it was warm out that day if one of the skipped a tooth when I started it that may cause all these issues?
Oh and how do I check my IAC valve? Would that cause any of this as well? Thanks guys I appreciate it.
Old Feb 20, 2008 | 01:01 PM
tvor's Avatar
I think it skipped a tooth. I'm going to check timing tomorrow and do a compression and leakdown test. I'll update this with the results then.
Old Feb 22, 2008 | 09:25 AM
tvor's Avatar
Update: Found a sizeable hole in my intercooler. Replacing that on Sunday and then seeing if this is fixed. If not I'm going to look for timing issues. I know all 4 cylinders are firing so I didn't burn up a ring or anything.
Old Feb 24, 2008 | 12:23 PM
tvor's Avatar
Update:
Replaced the intercooler and that helped a bit, but I still have a very rough idle and low vacuum. I still think that one of my cam gears skipped a tooth somehow.
Does anyone know if these symptoms would be common of a skipped tooth?
Old Mar 20, 2008 | 07:09 PM
tk2481's Avatar
any update?
Old Mar 21, 2008 | 12:19 PM
tvor's Avatar
Yeah it still runs like ****. Checking the timing today.
Old Mar 21, 2008 | 04:00 PM
tvor's Avatar
Compression test starting at the passenger side
150. 185. 180. 182.
Tell me it ain't so... suggestions?
xxorathaa
May 7, 2017 06:36 AM
VtexGt3
22
Oct 9, 2016 08:11 AM
Evo47
Dec 10, 2015 09:46 AM
EAC222
Jul 26, 2015 05:23 PM
