E85 question
Old Feb 22, 2008 | 05:38 PM
2highpsi's Avatar
E85 question
What would happen if you ran a car that was set up for E85 (fuel pump, 1000cc injectors, tune) and got somewhere where there was no E85. If you put 93 in the tank and stayed out of boost would it be okay. Obviously you would create a rich situation, but dangerously rich? Would anything get hurt. What else could you do?
Thanks in advance
Old Feb 22, 2008 | 06:38 PM
Liqquid's Avatar
you might want to invest in a laptop/cable and a map for the pump gas just in case you have to switch... if I recall the E85 map would be so rich if used with pump gas... I really don't think it would run!
Old Feb 22, 2008 | 06:43 PM
2highpsi's Avatar
what kind of cable? what software do i need to do this? Can i find predone maps just to get this car home?
Old Feb 22, 2008 | 06:55 PM
evilempire76's Avatar
Do you have any mods done to your car? You need a tactrix cable (www.tactrix.com) so you can have a tuner tune your car for any mods. The program they use to tune your car is usually ecuflash, but other types of engine management exist as well. To run E85 you need an upgraded fuel pump and larger fuel injectors at least. Do a search on e85 and you will find a lot of information.
Old Feb 22, 2008 | 07:05 PM
2highpsi's Avatar
thanks for all the info again guys
see i have found a lot of info on going TO e85. but this car im looking at ALREADY HAS e85 setup. i need to figure out how to get it home safely and i have no e85 stations around my town
Old Feb 22, 2008 | 07:13 PM
taenaive's Avatar
I would put 87 gas and drive slow. closed loop operation should take care of the overly rich condition for part throttle driving. It will be still rich though...
Old Feb 22, 2008 | 07:36 PM
Gotcha. Then to get home you will need a new tune for what ever pump gas you have available in your area.
Old Feb 22, 2008 | 07:41 PM
Liqquid's Avatar
+1, find out if the car was tuned using ECUFlash. If so, you can get a laptop/tactrix cable/and an email-flash to load up when you get it.
Find out what engine management is on the car
Old Feb 22, 2008 | 07:46 PM
2highpsi's Avatar
i was afraid of that. anywhere i could find a generic 93 oct conservative tune just to get me home then i can find out exactly what all has been done to the car and tune accordingly?
Old Feb 22, 2008 | 07:49 PM
2highpsi's Avatar
another thought...... if i throw some 600cc injectors in it would that work on the e85 tune??? ( again just to get it home probly 500 miles) That should take care of the rich problem. how hard is it to swap injectors on these?
i know this all sounds stupid but ive never had an evo b4 nor have i dealt with e85. ive had wrx and dsms
Old Feb 22, 2008 | 08:04 PM
dsmfan95's Avatar
Why not get the person to reflash it back to 93octane?
Old Feb 22, 2008 | 08:06 PM
FastLearner's Avatar
E85 Expert
I would suggest contacting Lucas English. You can get contact info from his website www.englishracing.net I would consider Lucas one of the foremost experts on running E85. He was able to give me an E85 map along with a map for 93 octane just in case I wanted to run it instead or none available on a cruise. As well you will need the interconnect cable and a laptop for the flash. Hope this helps.
Old Feb 22, 2008 | 08:10 PM
2highpsi's Avatar
dealer car, they have no idea
thanks for all the info, im gonna look into this englishracing
Old Feb 24, 2008 | 07:18 AM
VishnuEvoIX2006's Avatar
if you want your evo to run on pump gas and e-85, get an intake manifold with dual fuel injectors, one for your 1000cc injectors and one for your 550cc injectors, and have a switch so you can switch to pump gas if you can't find a e-85 station...ams sells an intake manifold with duel fuel injectors, i think the whole setup will cost around 2g's...
rico05
May 9, 2017 12:52 PM
bluedemon199
May 4, 2017 07:08 PM
4b11slayer
Dec 5, 2016 06:37 AM
ridenrunwv
Sep 27, 2015 07:03 AM
Tampa Evo
Sep 18, 2006 09:17 PM
