Why use other mods, if increasing boost can get the power you want...?
Hello All, I have a friend who has an EVO V, and had to get cams, headers and many other mods to get to about 300 WHP with 1.2 bar boost...
My car on the other hand just has a modified head, and a boost of 1.5 bar and also getting 300 WHP...
What is the difference? Would it be worthwhile for me to get the other mods and lower my boost? On paper it seems like they are both thesame, and the cost of my mods are a lot less...why would people spend more if it is just thesame, and you can just increase boost?
sorry if this seems like a noob question...
Ah thanks, now it makes sense...maybe for 300WHP, which is not the crazy for our cars, increasing boost can work...but then the turbo will be worked harder and probably not last as long...
For more than 300WHP then other bolt ons are needed...
Is this a true statement:? Having other mods help increase power aside from increasing boost, will give less stress to the engine.
For being able to track the car and drive it hard longer...it is better to have lower boost, cams, headers to get the power?
Which mods exactly help create faster spool? When you say faster spool, it means that the boost will start coming in at an earlier RPM? Or just spool faster when you are off the throttle say in 5,000 RPM and get back on the throttle, you'll be able to achive full bosst faster?
Just throwing this out there as a technical comment about increasing boost. I don't know if there is a difference is turbos from the V to the VII.
One thing about increasing boost is if you start to increase boost and start to go beyond the efficiency of the turbo itself then the turbo will increase the air temps even more which will in turn decrease the charge density (less amount of air per unit volume) which becomes counterproductive at a certain point.
Just another thing to look into when comparing the difference between his setup and your setup. Hope this helps.
Yeah, so I guess as a rule of thumb, the lowest boost needed to achieve the power you want is really more ideal....
What is a good next mod to do with this car...? I am looking for driveability more than peak power, as I use my car for DD and as a weekend track warrior...
Headers?
Cams?
Any other bolt on mods?
Any brands I should look into?
Headers?
Cams?
1) Your friends turbo will last longer
2) Your friends turbo can also run 1.5 bars
3) It gets to a point where more boost equals less torque and less power
Carlos
Carlos
arpad
179
Feb 9, 2020 03:51 AM
mda56
E85 / Ethanol
69
Jul 5, 2017 07:52 PM
mda56
15
Mar 30, 2016 12:33 PM
BigBoogieman
64
Nov 10, 2003 01:45 AM
