Inside the Brian Crower 2.6L stroker...
Old Mar 1, 2010 | 07:20 AM
  #151
High_PSI's Avatar
Originally Posted by project_skyline
If you think the 2.6 is going to be reliable with any high amount of power and/or rpm's your outta your mind. Not only is it made by BC but it takes the engine to its absolute limits both physically in the block and the components.
This is what I am saying, I am no engine expert but I know a thing or two about sever rod angle and the length of the stroke. Maybe if this engine was converted to Diesel with an RPM limit of 3800.
Keep it simple with the 4G63.
2.0 with a 9.0-1 compression will last you a life time and make all the power you want. Wana get cute? Try a 2.1. Other then that 2.3's are available for a nice street care but aren't all the drag records held by a 2.0?
Old Mar 1, 2010 | 07:26 AM
  #152
mr.alex's Avatar
Please elaborate...
Old Mar 1, 2010 | 08:19 AM
  #153
High_PSI's Avatar
Originally Posted by mr.alex
Please elaborate...
The rod angle alone would spell catastrophe, meaning with every revolution the angle the rod has to take under a power stroke is way to strong and would put tremendous stress on them.
Second is the piston speed itself, it would be higher then that of an F1 car at 8000RPM's.
If it were a diesel, then year run a ridiculous stroke as the RPM's don't get that high.
Old Mar 1, 2010 | 08:43 AM
  #154
mr.alex's Avatar
I've already commented on the F1 comparison...
All the experts in here, yet I am living proof that it works just fine.... Against all odds
Old Mar 1, 2010 | 05:12 PM
  #155
miragevo's Avatar
Veteran: Navy
I am a believer!!!! This is the ultimate street/track motor. Post an in car video of this bad boy ripping through the gears.
Old Mar 1, 2010 | 06:32 PM
  #156
Murf's Avatar
Just wondering engines HP and TQ cross at 5250 rpm.. what was done to make yours cross at under 4500?
Old Mar 1, 2010 | 07:43 PM
  #157
High_PSI's Avatar
Congrats, get some quality vids up, I wana hear that engine note.
Old Mar 1, 2010 | 11:00 PM
  #158
mr.alex's Avatar
Haha, that´s funny!
Edit: Cuz you were joking right? The HP and TQ scales are different....
Old Mar 1, 2010 | 11:44 PM
  #159
project_skyline's Avatar
You just told us the car has barely gotten any use... Its not like the thing has seen tons of abuse and use.
How many miles are on the motor?
We can argue all day long about the quality of BC components... It comes cheap for a reason.
Old Mar 2, 2010 | 01:59 AM
  #160
mr.alex's Avatar
Cheap? that's over 3k for crank, rods and pistons.
Eagle crank/rod and wiseco piston combo... That's cheap! Yet people run tons of power on them....
car has seen 8000 miles so far, no DD.
Old Mar 2, 2010 | 04:13 AM
  #161
Ok so maybe not real cheap. So FAR your the only person I have seen run this thing, and its not even the standard kit all over.
And you have only reved it to 7500!!! Thats barely enough rpm's to run a mid 11 at the strip much less have any fun with bigger turbo's.
Take it to 9500 like they say and then I'll eat my words and praise the kit if it doesn't blow up.
Old Mar 2, 2010 | 06:03 AM
  #162
Murf's Avatar
Haha, that´s funny!
actually NO...for someone into racing you should know that all engines HP and TQ curves will intercet at 5250 rpm. I was wondering why yours intercets under 4500 rpm.
http://www.oddparts.com/acsi/defines/torque.htm
NOTE: exceptions in diesel engins
Old Mar 2, 2010 | 03:16 PM
  #163
[I.R.A.]_FBi's Avatar
if the units/scale are different eg 10 hp per 10 mm vs 12 tq per 10 mm they will not intersect at 5250
Old Mar 2, 2010 | 03:25 PM
  #164
sabastian458's Avatar
that link looks like it is talking about electrical motors and not engines. Math might be the same/similar, IDK. But it is worth mentioning that if you click the other links on the page, that it doesnt talk about Gasoline engines.
Old Mar 2, 2010 | 03:36 PM
  #165
HP = rpm x T(torque) / 5252
if rpm = 5252, hp = tq
