Inside the Brian Crower 2.6L stroker...
Old Jan 17, 2009 | 07:09 AM
  #121
prodigalsunn's Avatar
Originally Posted by 94AWDcoupe
It is on the shoulders of the engine builder to determine during assembly whether parts are going to work or not. While I dont support selling parts advertised as ready to install that aren't machined correctly. IT IS still up to installer to determine potential problems during install. It amazes me you toasted 3 motors and blame the parts and not the builder.
exactly. it's like buying a set of hair clippers, then sending back the clippers because your hair ended up like this when you cut it.
Old Jan 17, 2009 | 08:13 AM
  #122
mr.alex's Avatar
+1
If the clerances were too tight on the first kit, why not measure the second one before assembly? not to mention the third one......
Yes, my motor works like a charm.
Old Jan 17, 2009 | 08:29 AM
  #123
Paul Nelson's Avatar
Originally Posted by mr.alex
+1
Much more behind the curtain stuff that happened. But yes i was newb when it came to evos at the time and listen to Brian and others who did not know what they were talking about with the 4g63 platform.
Now what this whole learning experience taught me was to go to people that know 4g63 inside and out. This whole ordeal is what lead me to English Racing From their ive hit 1100whp ran 8s and went 166mph.
But remember i was getting calls from other machine shop who were running into the same problem that we ran into. But they stopped and said wtf did some research and sent the kit back.
Old Jan 17, 2009 | 10:25 AM
  #124
wspy's Avatar
Hey Mr Alex, how high do you rev your motor to and what kind of racing do you use the car for?
Old Jan 17, 2009 | 03:02 PM
  #125
mr.alex's Avatar
7500rpms, only track days.
Old Feb 17, 2009 | 01:28 PM
  #126
chris_r_w's Avatar
It seems to me that there were problems with the 2.6L kit in the beginning back in '06.
It is also apparent that the problems (whatever they were) have been addressed.
Mr Aklexs' car is testiment to the fact!!!!
Check POST #83 https://www.evolutionm.net/forums/6557988-post83.html
That is quite simply the most beautifull motor I have ever seen. Amazing work
Old Feb 18, 2009 | 12:20 PM
  #127
High_PSI's Avatar
It's amazing you can get 2.6 out of the 4G63. I woulder how bad it hurts topend and longevity. Simply amazing though to get that out of a 2.0
Old Feb 18, 2009 | 12:23 PM
  #128
mr.alex's Avatar
You can't, that's why you use a 4G64
Old Feb 18, 2009 | 01:39 PM
  #129
project_skyline's Avatar
If I had money I'd buy this kit and rev it to 9500 and see if its really what they claim then end the debate.
DMF doesn't really have much info on their site other then bragging 1100bhp.... it would be nice to see some actual dyno, rev numbers from it.
I've never been impressed by BC stuff, sure its cheap but its nothing special either.
And from the looks at that dyno graph from Mr. Alex, the spoolup isn't that impressive either.
Old Feb 18, 2009 | 01:57 PM
  #130
mr.alex's Avatar
200whp and 300wnm at 4000rpms and after that it's a rocket, what more do you expect? it's still a 4 cylinder engine and compared to the 2.3l stroker which gives roughly 500rpms earlier spool than a 2.0l i would say that my engine has more or less spot on 1000rpms faster spool than a 2.0l engine would have with a same size turbocharger.
Old Feb 18, 2009 | 02:31 PM
  #131
R/TErnie's Avatar
Using 88mm stroke for the stock 2.0L and 106 for the BC stroker. Average piston speeds are in meters per second. Note...peak piston speeds are not listed, but every piston has to stop twice for every revolution...so it only goes faster between each stopping point (TDC/BDC)
RPM 7.0k 7.5k 8.0k 8.5k 9.0k 9.5k 10.0k 10.5k
2.0: 20.5 22.0 23.5 24.9 26.4 27.9 29.3 30.8
2.6: 24.7 26.5 28.3 30.0 31.8 33.6 35.3 37.1
FYI, if BC claims that they can rev the 2.6L to 9,500 rpms it will have the same avg piston speed as a 2.0L revving to 11,500. 33.7 meters per second! A formula 1 engine has a mean piston speed of 25 meters per second.
Paul,
do you still have that mechanical oil pressure gauge?
The 2.6L is a terrible idea IMO...
Old Feb 18, 2009 | 02:40 PM
  #132
05ah8james's Avatar
Very cool, but I imagine that the rod/stroke ratio is crazy on this thing...
Anyways, Its always cool to watch something new come up! I bet this thing is a blasty blast to drive!
Old Feb 18, 2009 | 02:48 PM
  #133
Bggstin's Avatar
We took my BC2.5L to 8250 on the dyno, it's seen 85-8600 once or twice. The 2.6 was just just built and shipped, we didn't dyno it so I don't have any rpm info for the BC2.6
SBR fit the 2.6 in a 4G63. Half the main girdle was gone but it was in there.
Sick car by the way!!
Old Feb 18, 2009 | 02:50 PM
  #134
mr.alex's Avatar
RPM 7000 7500 8000 8500 9000 9500 10000 10500
Paul,
I don't know why you people keep bringing this up but a formula 1 engine has nothing to do with our engines. You can easily rev a 2.0l engine to 10,000rpm as long as it is zero balanced and the valvetrain can handle it. But then again we would be breaking F1 regulations
If you want to talk about geometry that is ok but it seems like you know very little about egines and base your statments on what you can find from google.
I would say the side loads are a bigger issue than the piston speed.
Old Feb 18, 2009 | 02:58 PM
  #135
Bggstin's Avatar
Also very true. Our 2G saw 12k. We were testing our MSD rev limit vs. AEM because we were having a problem. Once we determined it wasn't the MSD, AEM got set at 12k so MSD would control all rev limits...and the MSD wasn't set back....long story short it saw 12k, without aluminum rods.
