Help Installing Exhaust Manifold
Old Feb 25, 2008 | 07:09 PM
KS_Evo9's Avatar
Guys im installing my exhaust manifold tonight and I need imput fast. Im needing a link on a HOW TO: Torque specs the whole 9 plz some1 help.
Old Feb 25, 2008 | 07:36 PM
evoix10's Avatar
INTAKE AND EXHAUST
SPECIFICATIONS FASTENER TIGHTENING
Air cleaner bolt9.0 ± 1.0 N⋅m (80 ± 9 in-lb)
Air cleaner bracket bolt9.0 ± 1.0 N⋅m (80 ± 9 in-lb)
Volume airflow sensor nut9.0 ± 1.0 N⋅m (80 ± 9 in-lb)
Air intake hose clamp bolt4.0 ± 1.0 N⋅m (35 ± 8 in-lb)
Air intake hose clamp bolt (air by-pass side)6.0 ± 1.0 N⋅m (53 ± 9 in-lb)
Charge air cooler Air hose and air by-pass hose clamp bolt6.0 ± 1.0 N⋅m (53 ± 9 in-lb)
Air pipe bolt12 ± 1 N⋅m (102 ± 13 in-lb)
Air pipe bracket bolt12 ± 1 N⋅m (102 ± 13 in-lb)
Charge air cooler bolt12 ± 1 N⋅m (102 ± 13 in-lb)
Charge air cooler nut12 ± 1 N⋅m (102 ± 13 in-lb)
Exhaust manifold and turbocharger Air outlet fitting bolt19 ± 1 N⋅m (14 ± 1 ft-lb)
Exhaust fitting bolt59 ± 5 N⋅m (44 ± 3 ft-lb)
Exhaust fitting nut59 ± 5 N⋅m (44 ± 3 ft-lb)
Exhaust fitting bracket bolt35 ± 6 N⋅m (24 ± 4 ft-lb)
Exhaust manifold nutM8 29 ± 3 N⋅m (22 ± 2 ft-lb)
M1049 ± 5 N⋅m (36 ± 4 ft-lb)
Exhaust manifold cover bolt23 ± 3 N⋅m (17 ± 2 ft-lb)
Heated oxygen sensor (front)44 ± 5 N⋅m (33 ± 3 ft-lb)
Turbocharger bolt64 ± 5 N⋅m (38 ± 3 ft-lb)
Turbocharger nut64 ± 5 N⋅m (38 ± 3 ft-lb)
Turbocharger heat protector bolt23 ± 3 N⋅m (17 ± 2 ft-lb)
Turbocharger oil feed pipe eye boltM1017 ± 2 N⋅m (12 ± 2 ft-lb)
M1231 ± 2 N⋅m (23 ± 1 ft-lb)
Turbocharger oil feed pipe bolt11 ± 1 N⋅m (98 ± 8 in-lb)
Turbocharger oil return pipe bolt (oil pan side)14 ± 1 N⋅m (120 ± 13 in-lb)
Turbocharger oil return pipe bolt (turbocharger side)9.0 ± 1.0 N⋅m (80 ± 9 in-lb)
Turbocharger water feed pipe eye bolt42 ± 7 N⋅m (31 ± 5 ft-lb)
Turbocharger water feed pipe bolt10 ± 1 N⋅m (84 ± 13 in-lb)
Turbocharger water return pipe eye bolt42 ± 7 N⋅m (31 ± 5 ft-lb)
Turbocharger water return pipe bolt10 ± 1 N⋅m (84 ± 13 in-lb)
Kinda confusing but i hope it helps good luck
Old Feb 25, 2008 | 08:00 PM
Exciting News's Avatar
^Good god man, you trying to give that poor guy a migraine? lol
Old Feb 26, 2008 | 06:40 AM
evoix10's Avatar
lol im new kinda....i wanted to post that same picture but i still cant figure out how to post pictures
Thanks for clearing it up for the guy
Old Feb 26, 2008 | 06:53 AM
meckert's Avatar
work from the inside nuts outward.
Old Feb 26, 2008 | 02:07 PM
KS_Evo9's Avatar
Thanks everyone
Old Feb 26, 2008 | 02:09 PM
Billy@EnglishRacing's Avatar
wow first to replays and you have every thing you ever wanted to know
Old Feb 26, 2008 | 02:38 PM
SPANKED's Avatar
Needed this too...thanks!!!
Old Feb 26, 2008 | 02:40 PM
4WS Tuning's Avatar
Make sure you let the car cool down completely and use pb blaster....
If you do it hot without it chances are youll break a bolt and thats never fun...
Best of luck!
Nabster86
Mar 6, 2017 04:46 PM
Nabster86
Evo X How Tos / Installations
Mar 5, 2017 08:28 PM
dolphin888
May 9, 2010 07:12 PM
black_beauty
Mar 30, 2010 08:10 AM
CarbonKrazyEvo9
15
Sep 18, 2007 10:13 AM
