Help with exhaust manifold install...
Old Mar 30, 2010 | 07:19 AM
black_beauty's Avatar
ok im tryin to install an exhaust manifold, i have the stocker off. When i put the other one back on i apparently didnt get it on square and have a mega leak right in the front where the 2 studded bolts are. I reused the stock thick metal gasket on the turbo side, put the new on the head side. What could cause the turbo side not to sit properly? I did take the 2 spring bolts out of the DP, anything else i need to take off to make this work correctly? Thanks
Old Mar 30, 2010 | 07:53 AM
cij911's Avatar
Are you sure you properly torqued all the bolts ? Have you re-checked the torque now that the car has been heat cycled ?
Old Mar 30, 2010 | 08:10 AM
i didnt heat cycle it, as soon as i started it was overly loud and i immediately turned it back off
wowzers
May 28, 2016 07:31 AM
wowzers
May 2, 2016 02:03 AM
Hiboost
Evo X How Tos / Installations
16
Feb 27, 2016 03:33 PM
ryukinevo
Feb 8, 2014 09:42 PM
Grimgrak
Jun 6, 2013 06:59 AM
