Eneos vs Amsoil
FYI Another EVO ENEOS test found on youtube. This is EVOX tho but eneos related.
http://www.youtube.com/watch?v=o_hgc54pxKc
http://www.youtube.com/watch?v=hmDRXmKk9m8
OK..... They don't even use oils that are Apple to Apple.. You can't compare a 20W-50 to a 0W-50 ...
I also love "A Leading Japanese Synthetic" compared to ENEOS... which IS The Leading Japanese Synthetic and may be the only Japanese Synthetic... The other oil was most likely a Hydro-Cracked oil... Again... Not an Apple to Apple comparison, so now, we have 2 things against an ENEOS Sponsored Film Clip..
Doc
Many don'r realize that "Mobil 1" is a company, not a product...
Just like AMSOIL where they have the most complete line of Synthetics in the World including the Best Filtration on the Planet.
Check your engine for sludge buildup. Good place to check is bottom of oil cap and inside with a flashlight...
No buildup, you are ready to change...
Doc
Oil Doc,
I just changed to some German Castrol 0w-30 Syntec because it's got nothing but good reviews from oil analysis reports and people that has been using it over the years. These were on sale for $20 for 5 Quarts and I stocked up on it. I've been wanting to try some Amsoil 0w-30 for some time, but seems like I have to get in on the Amsoil membership to get a better price for them.
What is your take on the German Castrol 0w-30 oil?
Thanks!
Thanks!
Probably a waste with that oil by changing so soon. You should be able to do 3000 miles minimum. Instead of just dumping the oil, pull an oil analysis. But make sure you use an ISO 17025 A2LA Accredited Lab. They utilize the strictest standards and the results are duplicatable.
Although Motul is a good oil, a full Ester Based oil can have it's own share of problems with seal compatability.
Doc
EP (Extended Performance) is a PAO Based oil where the others are Hydro-Cracked Group III Products at best.
Thanks, guess for the longest time i thought the only distinctions were between weight and as long as you were using synthetic it was fine. Is it possible for oil to increase HP as that biased youtube video shows?
Yes, it is more than possible, it is fact and AMSOIL has proven it for 35 years.
Where my problem lies with the youtube video is that they conveniently cover the label of the competitor. They are also testing different viscosity oils. Sounds just like they took their marketing practices from the Royal Purple Pages... "Against Leading Synthetics" what a crock...
AMSOIL Names their competition right on the bottles, cases and in print. If what they said was false, there would be lawsuit after lawsuit filed.
Also.... Fine, it increases HP.. what about wear ? Shear Stability ? Let's see ASTM Tests... That is what I would like.
Doc
Oil Doc,
Thanks!
Thanks!
You don't have to buy a membership to get the best prices from AMSOIL, you just need the right contact that will sell Forum Members at Dealer Cost.
Doc
