Question about timing belt change. . .
Old Feb 28, 2008 | 10:19 PM
subrwho's Avatar
In about a week i'm going to be having my cams as well as a new timing belt installed. Now my question is, is should I have the tensioner replaced as well? Is it really necessary? And if I do need it, I found three different things on mitsubishiparts.net. Is it the Tensioner, Tensioner adjuster, or the tensioner pulley? Thanks in advance. . .
Old Feb 28, 2008 | 10:46 PM
subrwho's Avatar
Up
Old Feb 28, 2008 | 10:51 PM
whoang40's Avatar
tensioner pulley, it's used to adjust the tension. Replace everything that's on the recommended service for 60K. If you're going through all that work, you might as well replace everything.
Old Feb 28, 2008 | 10:56 PM
tripperfx3's Avatar
+1. Just replace it all. Im at 52k and getting ready to do cams, so I'm just going to have them go ahead and replace the timing belt, headstuds, etc. as well.
Old Feb 29, 2008 | 04:19 AM
itzwolf's Avatar
I highly recommend replacing everything while your in there. Do it once, do it right.
Old Feb 29, 2008 | 04:48 AM
rcheung's Avatar
You'll need the tensioner , the two pullies you found, timing belt, water pump.
Old Feb 29, 2008 | 04:56 AM
cheb evo's Avatar
Here is a kit from mitsubishiparts.net that I picked up for the timing belt change. Has everything including the water pump...will save you about $500 compared to the price from the dealership
http://www.mitsubishiparts.net/catal...ction=586#1523
Old Feb 29, 2008 | 04:58 AM
rcheung's Avatar
Wow thats a good deal. I wonder if they had that when I got my parts months ago.
Old Feb 29, 2008 | 05:00 AM
EvilBlueEvo8's Avatar
if you are at 60k or above and doing the timing belt, wont hurt to shell out for a new water pump too. reason being is that you have to pull the timing belt to do it and pumps generally last 75/80k miles. spend the cash now to save more in the long run.
Old Feb 29, 2008 | 05:16 AM
cheb evo's Avatar
Not sure when they first posted that, I just did mine last month. I bought this kit and paid a shop $440 to do the complete install...about $850 total. The dealership quoted me $980 just for the parts let alone the installation...so going this route will definitely save you money.
Old Feb 29, 2008 | 06:22 AM
C6C6CH3vo's Avatar
Has anyone used a slightly underdriven water pump as a bolt on?
Changed my timing belt at 50K, reused the tensioner and pump due to budget. Waterpump, tensioner, alt, and battery will get replaced at 70K.
heavens turbo
Aug 3, 2016 10:02 AM
stefenboy
Dec 9, 2015 03:20 PM
cmiller10
Oct 10, 2014 08:04 AM
lilredevo
15
Dec 15, 2009 11:27 PM
Motoxrider7
Nov 8, 2008 04:22 PM
