Cam instalation question
Old Nov 8, 2008 | 10:13 AM
Motoxrider7's Avatar
I just put new cams in my evo. Now i have a new timing belt and tensioner. Do you HAVE to install a new belt and tensioner. ?
Old Nov 8, 2008 | 12:19 PM
HyaboostaIX's Avatar
The only time you HAVE to install a timing belt is when your old one is worn out. If your car has around 60-70k miles, it's also a good idea. The tensioner does not neccessarily need to be changed either, but it's always a good idea to change it when you do the belt since the job blows. But yes, you can change cams without changing your timing belt.
Old Nov 8, 2008 | 12:59 PM
takeshi999's Avatar
as he said...you don't need new belt or tensioner unless it's due...and tensioner is one of those things where it is easier done with the belt then later...
Old Nov 8, 2008 | 04:22 PM
Alright so im alright with what i have now. they were just replaced 10k miles ago thanks guys !
snapb1
16
Mar 8, 2023 07:57 AM
stefenboy
Dec 9, 2015 03:20 PM
TommiM
Jul 8, 2009 07:32 PM
subrwho
10
Feb 29, 2008 06:22 AM
espritv8
Nov 16, 2005 08:02 AM
