SUPER lightweight Carbon fiber rotors, interested?
Old Mar 26, 2008 | 03:12 PM
  #61
awdboosted's Avatar
If the statments about the porsche brake apply to us.. Id be interested.
Pending on
-If the Brembos can take the abuse? If heat becomes a factor with them?
-Noise and how the performance compare to a high end pad and rotor?
Old Mar 26, 2008 | 05:19 PM
  #62
jdmpurest's Avatar
Only problem with carbon ceramic on the street is if you don't regulary heat cycle them right they glaze and then don't work for ****. My dad has a few porsches, he has a 996 turbo with with carbon ceramic option and before he understood the process he was pissed because his car wouldn't stop for ***, he tried to take his car to the dealer and they explained its common among porsche owners. You have to heat cycle them properly to keep them fresh.
Old Mar 26, 2008 | 05:33 PM
  #63
ray3328's Avatar
any updates?
Old Mar 26, 2008 | 07:12 PM
  #64
David Buschur's Avatar
No updates.
Old Apr 11, 2008 | 10:33 PM
  #65
cal1mr's Avatar
update?
Old Apr 13, 2008 | 02:17 PM
  #66
Yes, actually. The carbon ceramic rotor probably won't happen because of cost/interest. It looks like there is going to be a single blade rotor built though from iron.
Old Apr 19, 2008 | 03:28 PM
  #67
cal1mr's Avatar
Oh man, this was right up my alley as I am done with my motor.
Old Apr 19, 2008 | 03:52 PM
  #68
ray3328's Avatar
that's too bad, it was a good idea though...
Old Jan 21, 2013 | 11:11 AM
  #69
wjamyers's Avatar
There's still no carbon ceramic options available for evos? is this a silly thing to want or is it just a matter of time?
any expert opinions on this?
Old Jan 21, 2013 | 03:34 PM
  #70
EvoDan2004's Avatar
id be interested in a super light weight rear kit since AMS stopped making them. not in carbon though. LOL.
Old Jan 21, 2013 | 07:08 PM
  #71
project_skyline's Avatar
Too expensive. Not enough people will want to pay $2000 or more for rotors and pads when that can get you full BBK upgrades.
Old Jan 21, 2013 | 08:13 PM
  #72
EvoDan2004's Avatar
BBK kit also weighs 15lbs more then a stock setup. this thread was for the looney's wanting every ounce out of the car.
Old Jan 22, 2013 | 12:04 AM
  #73
irace2much's Avatar
Yes lower waight= lower E.T.
Old Jan 22, 2013 | 08:26 AM
  #74
GTijoejoe's Avatar
Its not 'glaze' as the technical reasoning as known on iron setup. For CCM or CC you need a film layer of the pad deposit on the disk, this is what gives you the friction stopping power, so you need a specific heat cycle. There is specific cycle for street driving and also for track, its normally in the owners manual for vehicles which come equipped from factory, basically just a series of stops like normal burnishing but slightly more specific.
Porsche actually has developed (with supporting supplier) another material variant of CCM as PCCB, utilizes a different process to change the surface condition of the disk, quite interesting and also madly expensive.
Carbon disks also require specific types of pads, there are pads which can be used on carbon and iron, but not the other way around, your iron pad will not work on carbon disks (properly, never recommended).
There are only a few makers in the world for carbon disks for automotive, since the production volume is so low and also such a long process compared to iron, it makes them crazy expensive.
To scratch wjamyers itch, this type of setup being proposed is more parallel to the light weight drag brake setups, meaning its actually decreasing your vehicles brake capacity over stock as you don't need it in drag racing... you use parachutes. So its basically reducing your light weight setup even further. Heat would become an issue for series brake users based on the size of what is being proposed.
If you want to match or exceed the stock evo's brake capacity in terms of heat (for roadrace track), you wouldn't be able to utilize any of the stock corner anymore. Carbon does not have the heat capacity as iron, so the disk would have to be much larger and the pad would have to be much larger than stock, so you would need a different caliper as it could not accept either disk or pad needed for carbon. When designing a setup for carbon, if you can not give ample cooling, then the disk has to grow significantly... and just to clear any confusion, carbon disks can get much hotter than iron because of the material, but they can not 'absorb' the type of energy as an iron disk can, aka heat capacity.
Because what I do professionally, I have a decent understanding of CCM, PCCB, and CC disks.
Smike
628
Oct 27, 2024 04:39 AM
Smike
63
Apr 29, 2019 07:27 AM
David Buschur
30
Jan 23, 2016 04:23 AM
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
280
Jul 13, 2010 04:49 PM
David Buschur
165
Feb 6, 2010 09:47 PM
