Wastegate ?'s
Old Mar 7, 2008 | 02:07 AM
TKEVO's Avatar
Veteran: Air Force
Wastegate ?'s
I have an Evo9 turbo on an VIII. I'm planning on running about 375-400hp. Can the stock evo 9 wastegate be able to hold that much or would I have to upgrade to the forge? I will be running a snow performance 2 meth system w/ cams, cam gears, ported exhaust manifold, invidia o2housing, reflash and so on.
Any info would be appreciated.
Old Mar 7, 2008 | 05:17 PM
TKEVO's Avatar
Veteran: Air Force
Any info what so ever?
Old Mar 7, 2008 | 05:20 PM
JordanS4's Avatar
forge or fp for sure. with the boost levels you will likely be running the boost will spike and quickly taper off. an upgraded unit will hold much more boost to redline. i personally experienced 4 psi more (30-22 before, 30-26 after). i have a fp for sale cheap if you want one.
Old Mar 7, 2008 | 10:20 PM
TKEVO's Avatar
Veteran: Air Force
how much and what brand is it?
06rallyred
Sep 4, 2014 09:30 AM
evoiao
Jul 19, 2013 06:59 AM
Boostfarmer
May 23, 2013 08:34 AM
Boostedx11
Jun 7, 2011 01:43 PM
AZ EVO IX MR
Sep 10, 2006 08:07 PM
