85mm drop in's, what checks to do??
Old Nov 18, 2020 | 12:31 PM
RS200's Avatar
Originally Posted by Lancer_Evo_8
Is there no worries / problems when i change the OEM Pistons with Wiseco 85.00mm Pistons? Or i have absolutly go 0.20mm over OEM
The car has under 25'000 mls
Mileage is a decent indicator of bore condition but is by no means the final variable. Measure, measure, measure to make sure that the cylinder has no distortion or wear, and set piston to wall clearance according to the piston manufacturer's specs. If any clearance is too wide for spec, it needs to be bored out.
Old Nov 18, 2020 | 10:28 PM
Jonno99's Avatar
I had worn rings and bore was still within spec, i thought of doing drop ins however the more i thought about it the more i thought stuff it, if im pulling the motor I'll do a 85.5 and refresh everything, I'm still glad I did.
Old Nov 23, 2020 | 11:07 PM
DATEVO9DOE's Avatar
5 Year Member
Dude most likely with that mileage you should have no need to bore out for oversized pistons , if ANYTHING maybe a light hone for a nice crosshatch pattern for the new rings.
