Evo OEM Air Filter Replacement.
Old Mar 14, 2008 | 11:53 AM
Burklow's Avatar
Originally Posted by Ev0cRaZy
I cant remember exactly what HKS recommended.
I think its like every 10-15k. I would take it out between oil changes and knock the dirt out.
I hope this isn't the same filter material they make for their mushroom open element air filters for the RS intake kit. They make gain, but suck in a lot more than just air. Look here and you'll see what I mean:
http://www.mkiv.com/techarticles/filters_test/2
Old Mar 15, 2008 | 01:52 AM
SunKren's Avatar
Thank you for the link, a very good test.
Does anyone happen to know what is the material used for the apexi filter in the test?
Old Mar 15, 2008 | 02:53 AM
hokiruu's Avatar
burklow thanks for posting the test link, that was the "proven" i was referring to.
someone asked about a paper panel filter. IIRC Blitz has one, same filter element material as thei LM cones, which i used with great success on my SR20DET.
sunkren, do you mean the "dirt" they used?
Old Mar 15, 2008 | 02:24 PM
SunKren's Avatar
Not really, I mean, what is the based material for the apexi filter? Cotton/paper? The apexi filter used on the test at the link given.
Old Mar 15, 2008 | 02:27 PM
hokiruu's Avatar
It's dry paper AFAIK. Could be some cotton in it. Excellent filter
Old Mar 15, 2008 | 07:38 PM
SunKren's Avatar
Agree.
Do you guys happen to know if the apexi box is bolt-on with evo 9 + the battrey?
Old Mar 20, 2008 | 02:04 AM
SunKren's Avatar
What would you guys recommend, Blitz drop-in filter or Works?
Old Mar 20, 2008 | 11:07 AM
hokiruu's Avatar
i have not used either in my evo
AFAIK Blitz is about half the cost of the Works, and is dry element whereas the Works is oiled
Obviously I prefer dry, and cheaper, so you know what I would go with.
The Blitz dry element worked very well for me on my SR20DET, and I live in a very dusty area.
Unless you are running significantly higher boost, I have my doubts that a drop-in (that filters worth it's presence) will net significant gains. Certainly not worth the $126 or whatever for a new Works, even though I like Works, it's just too expensive to justify it IMO. I use the stock filter.
Old Mar 20, 2008 | 11:23 AM
CULVIIIER's Avatar
Cut out a piece of screen and throw it in there and clamp the top down over it, works for me!
Old Mar 20, 2008 | 12:01 PM
lords3t's Avatar
I'm really glad I came across this thread. Every weekend, when I go through my checklist, I always end up cleaning out the air box. I'm running - not for much longer mind you - the K&N rechargeable drop in, and it has been coating the inside of my air box with charge oil. Just picked up an HKS filter from lancershop. When I get that one in, I'll try it out and see if it's good enough or if I need to try something else. HKS has been good to me so far, so I'll most likely be happy enough (with it being a drop-in replacement, I'm not expecting much).
Old Mar 20, 2008 | 12:23 PM
Spent198's Avatar
Works drop-in, hands down.
www.worksevo.com
-Carl
Old Mar 21, 2008 | 03:03 AM
SunKren's Avatar
Does anyone know how much improvement the blitz cover gives compare to stock's cover?
Old Mar 21, 2008 | 07:06 PM
hokiruu's Avatar
www.worksevo.com
-Carl
why?
Old Mar 24, 2008 | 09:42 PM
SiNiStEr_EvO's Avatar
Bump
I too am looking into getting a drop in. I thought k&n was suppose to be good but from what i see people are complaining about them?
I would like to hear more about blitz. Hows its filtration comapred to stock and compared to oiled ones?
LancerShop.com
21
Sep 23, 2016 06:11 PM
ECS Performance
39
Oct 7, 2013 01:03 AM
miragevo
10
Dec 30, 2010 07:30 AM
PERRIN_JOHN
EvoX 'For Sale' External Engine / Power
May 17, 2009 08:49 PM
EvoMoto
10
Sep 26, 2005 01:54 PM
