My Dyno Dynamics pulls...
Old Mar 18, 2008 | 07:49 PM
  #31
DG Motors's Avatar
Originally Posted by urslo4n8
Thanks for clearing that up Pete. I printed out the NEW/IMPROVED graph.
Not a problem, i am glad you understand everything and i will get criticized for everything that is not 100%. Thanks for putting up with everything and i can assure by the next time you come out, there will be no questions on how your graph turns out
Old Mar 18, 2008 | 07:52 PM
  #32
DG Motors's Avatar
Originally Posted by evovin
Ted, Isn't that DYNO4MANCE is using Dyno Dynamics too???
Is there something wrong with this particlular dyno?(the one above 1st page)
I am just hoping to get the right tune .....
There is absolutely nothing wrong with my dyno. I cleared everything up already why the hp/tq was not crossing at 5252 rpm. Ted actually did me a huge favor by mentioning it and it enabled me to do some research and fix the problem. Check on page 2.
Old Mar 18, 2008 | 08:41 PM
  #33
CharlieGsanD's Avatar
Originally Posted by evo8604
Are you talking about the long dip at the end of the run after 7000rpm? This dyno requires quite a few things to be done at once . The numbers are spot on, that is what counts. If you want me to explain that too i have no problem.
was actually referring to the jagged horizontal movement along the curve.
ran a few of these dyno's myself, though i cant say ive used any W the new software. but typically when i see that horizontal jumping it is because of too low of a gain setting on the tach box, or the converter box for the indictuve pickup was too close to a coilpack.
sorry if i came across wrong, just figured ive seen this so id toss it out & didn't give much thought to how it may sound. didnt mean any disrespect, just a bad habit of mine
Old Mar 18, 2008 | 08:49 PM
  #34
DG Motors's Avatar
No, thanks for the information, i appreciate it. I will have to check it out. You recommend farthest away from the coil pack? i know the calibration for setting the tachs are on spot every time so it can't be anything else making those jumpy lines.
Old Mar 19, 2008 | 02:35 PM
  #35
i take it you were using the inductive pickup?
on the Tach Box there is a knob to change the gain for the signal. to establish a good baseline, rev the motor unloaded to 3/4 of max rpm & adjust gain knob so you have a steady tach signal.
unless they changed the hardware, there is a converter box if you will that is used to change probe type. this box will pick up EMI noise of it is too close to the coilpack or other high voltage wires
Old Mar 19, 2008 | 03:31 PM
  #36
EvoTech's Avatar
Wow. A thread with curtious critique and information that was actually helpful to someone. What a nice change.
Old Mar 19, 2008 | 03:50 PM
  #37
DG Motors's Avatar
Excellent advise, Thank you. I do have an inductive pick up that clamps down on the chosen wire. I also have a tach box that will match rpm to the c.p and car. I have been doing it this way on an idle. I have also tried bringing the car up to 50mph in 3rd or 4th gear to match rpm in the car and on the c.p if it did not work on idle. Even though i have not tested your advice on keeping the inductive pickup further away from the wire(s), i am almost positive what you said will solve the problem. On a side note, i did pull a few graphs from a 240sx, turbo civic, and a few mustangs and the lines were nice and smooth, most likely due to the wires being much longer...
I really wanted to do some testing today, but we painted the floor around the dyno and put down some black and white tiles to clean up the area. Tomorrow i will be on the dyno giving this another shot.
Old Mar 19, 2008 | 03:54 PM
  #38
DG Motors's Avatar
Yes, i am surprised, a lot of people on here usually point fingers and put each other down.
Yes, i am new to using this machine, i will make mistakes, i am human and thank you everyone who has been helpful. I will be having a test and tune day really soon at no cost other than a wide band hookup to give back to this great community.
Blacksheepdj
Lancer Engine Tech
146
Aug 9, 2022 08:45 PM
SickSilverNLow
18
Aug 1, 2008 01:34 PM
konad
33
Mar 18, 2008 08:44 AM
metzpl
For Sale - Cars For Sale
23
Feb 2, 2008 11:15 AM
Rival
Mar 25, 2007 08:12 PM
