Tial BOV Question
Old Mar 17, 2008 | 11:13 PM
1NastyMR's Avatar
Tial BOV Question
Is there a way to adjust how the Tial bov sounds?
Old Mar 17, 2008 | 11:18 PM
James@DSR's Avatar
The sound is due to how much boost you run. With how much boost we run on our cars its hard to really change the sound...how bout getting another blow off?
James
Old Mar 17, 2008 | 11:25 PM
1NastyMR's Avatar
Whats wrong with tials? My buddys evo has a tial and his sounds totaly different compared to mine we both run same boost levels.
Old Mar 17, 2008 | 11:27 PM
tripperfx3's Avatar
Are you both running the same turbos? Some turbos flow more air at higher boost. Either that or one of you may have a boost leak and not know it.
Old Mar 17, 2008 | 11:29 PM
1NastyMR's Avatar
We both are tuned at 21lbs and did total boost leak checks no leaks found. My tial sounds like a greddy RS or HKS SSQ in a way. When it goes off the sound flutters a few times.
Old Mar 17, 2008 | 11:54 PM
staatz's Avatar
Tial at 34psi sounds pimp
Old Mar 17, 2008 | 11:56 PM
1NastyMR's Avatar
Mine make the same sound low boost or hi boost its weird
Old Mar 17, 2008 | 11:57 PM
staatz's Avatar
Wat turbo do you have? Stock? and what is "low boost" and "high boost" to you?
Old Mar 18, 2008 | 12:05 AM
1NastyMR's Avatar
Stock IX turbo low boost 14 psi hi boost 21-23
Old Mar 18, 2008 | 12:20 AM
Slava's Avatar
The spring in bov might be too strong. And if it is the case that BOV will make fluttering sound. Just verify which spring you have in your BOV. Also if you have cams your vacuum goes down and you need weaker BOV spring. hope that helps.
Old Mar 18, 2008 | 12:28 AM
1NastyMR's Avatar
I believe it has a 11lb spring and yes i have cams
Old Mar 18, 2008 | 12:32 AM
Boost3dxEvO's Avatar
Does it just flutter ALL the time??? I am very familiar with the Tial bovs as I personally run one and have taken it apart a few times...
Old Mar 18, 2008 | 12:33 AM
1NastyMR's Avatar
It flutters always compared to my friends which goes off just once like almost all tials Ive seen and heard before.
Old Mar 18, 2008 | 12:34 AM
Are you both running the same spring? And also, the same boost?
Old Mar 18, 2008 | 12:35 AM
staatz's Avatar
Just upgrade the turbo and the thing will sound sexi
