which meth kit to get to hit my 500hp goal
Old Mar 19, 2008 | 03:31 AM
spooch's Avatar
Alright guys ive done alot of searching and have not come up with the best solution
I have an 03 evo that basically is sitting close to 350whp. I had it witha 20g-lt on it and took it all off and decided for the ets 57
I have the following items to put on
Ets 57 trim kit
arp head studs
arp rod bolts
Ebay clone fmic
Buschur Uicp
Brian crower 272s
Act Hdss clutch kit
rsr gt2 3 inch test pipe back
walbro 255
stock ecu, stock maf
Have not ordered injectors yet, i am 90% sure im going to get 880cc's
The car is my daily driver, id like to be able to hit 500whp with 93 oct and 100% meth injection. Obviously I wouldnt be driving around all day with 30psi but Id like to make 500 on the dyno and If i had to use race gas with meth to get it, so be it
Which meth kit is the most reliable ? Which one do you recommend to me, I dont want it to fail so I'm not going to go with a cheap used kit. Thanks
Old Mar 19, 2008 | 05:07 AM
deadbeatrec's Avatar
Ets 57 trim kit
arp head studs
arp rod bolts
Ebay clone fmic
Buschur Uicp
Brian crower 272s
Act Hdss clutch kit
walbro 255
first off 880cc's are too big. no need for that much injector. u are just going to make it harder for your tuner to tune them.
secondly, as far as alky kits are concerned, i like my HFS-1 aquamist. great quality.
Old Mar 19, 2008 | 06:44 AM
KevinD's Avatar
may i suggest:
https://www.evolutionm.net/forums/sh...d.php?t=303228
Old Mar 19, 2008 | 07:44 AM
justboosted02's Avatar
aquamist hfs-5
Old Mar 19, 2008 | 07:50 AM
xiaoni420's Avatar
Aquamist HFS-1
Old Mar 19, 2008 | 08:23 AM
TTP Engineering's Avatar
Many of the fastest stock turbo Evo's for 2008 are using our meth injection systems.
Old Mar 19, 2008 | 08:31 AM
PwrEvo's Avatar
KevinD's preassembled Aquamist HSF-5, great kit and the easiest install.
Old Mar 19, 2008 | 10:01 AM
spooch's Avatar
so you guys think with the aquamis hsf-5 kit i should have no problem hitting my 500whp goal
Old Mar 19, 2008 | 10:56 AM
KevinD's Avatar
i'm running the HFS-5 and i make 500whp, so yeah, it wont be a problem at all
Old Mar 19, 2008 | 10:59 AM
scheides's Avatar
EvoM Moderator
Aquamist HFS-1 or HFS-5 absolutely nothing else. Read through the install I just did here:
https://www.evolutionm.net/forums/sh...d.php?t=330062
And then if you want it to be painless, Pm ^ KevinD ^ and order one of his pre-assembled setups. I LOVE this kit, I had an SMC before and I am glad I made the switch. Super driveable, reliable, and actual failsafes built in.
Old Mar 19, 2008 | 11:13 AM
StevenStarke's Avatar
I personally still stick my SMC failsafe or not, I've never had a problem, nor have any of my customers
SickSilverNLow's Avatar
Aquamist is pretty good company to go with......you should have no problem making 500whp on meth and pump with that turbo...i hit a little over 400whp with just pump with the ETS 57trim.
Old Mar 19, 2008 | 11:19 AM
staatz's Avatar
SMC alky, 100% 93 OCT, 618whp SON..Lol
But seriously..on my old evo I had 780cc's and 100% alky and the car made 500whp so you would be fine with whichever alky kit you decided and 780cc's
Old Mar 19, 2008 | 11:37 AM
dafunk630's Avatar
SMC here and 501 whp!!!
Old Mar 19, 2008 | 11:42 AM
staatz's Avatar
AMEN!
