Spark Tech's 1000+HP Pro Drag 4 System..
Hey Zyber....We'll have your system completed and on the way to Sweden next week. The coils are not an issue on your setup. This is only due to the 250milli joules that the Pro-Drag 4 has. Your set up with the motec system will work well
Having a wasted spark system on a drag car is not maximizing the cars or tuners potential. Lets face it 60psi of boost is not the easiest mixture to ignite...would you rather have 52.5milli joules going to each spark plug or 250milli joules? When wired in wasted spark as it has to be for stock ecu which only has 2 channels (outputs) you are splitting the power output into 2 ...The Pro-12 wired in wasted spark has proven to work over 1000whp which is already amazing and is sufficient for 95% of cars out there. However Pauls car and all the top drag evo's do not fall into that catagory. Since ALL 700whp and above cars will have some type of standalone with 4 channels (outputs) why not reap the benifits of Sequential ignition?
We feel there are several benifits and advantages to utilizing this system and will offer it as an option.
I am all for sequential ignition over waster spark on ANY car - only reason to run wasted spark is if you have the stock ecu which only has two channels or to save $.
My only concern is that I was told that the drag box is a unit which can only run for literally seconds before it starts to get overly hot.
I was able to run the wasted spark M & W system as sold by Buschur to 1,000 whp with ease. Trying to approach 60 psi of boost it started to have some miss fire. But it is still on the low output mode. When I get the car up and running I plan to test it on high output mode and see how much power I can get.
damit to hell. hum. i guess ill just buy another evo 8 c.o.p. and mount it on the wall in my garage just too look at it. there that nice and that worth it. f posters. im hanging parts.
It start's to drop in some nice parts now, first the MoTeC, last week my Stätus Racing kevlar seats, next week I hope my turbo comes and then this
We are starting development on a system for the Evo x.....what are u gonna do?
