help a noob, what did I break
Old Mar 26, 2008 | 09:50 PM
evotuner04's Avatar
15 Year MemberLikedLoved
well dude it sounds like your driveshaft is it under warranty still?
Old Mar 26, 2008 | 10:03 PM
Jameson_IXMR's Avatar
Post a video of the sound, it is probably the heatshield that is mounted to the car (not the exhaust pipes). It tends to hit against aftermarket flanges as they are larger than stock.
Old Mar 26, 2008 | 10:54 PM
evotuner04's Avatar
he said everything is tight nothing is loose on the exhaust....which points to the driveshaft!!!!!!
Old Mar 27, 2008 | 12:12 AM
ill born's Avatar
I would check the lug nuts first.
Old Mar 27, 2008 | 02:22 AM
s10v8's Avatar
I had the same prob when I installed my downpipe. I forgot to put spacers on the small black bar that runs across the underside. And the downpipe would rattle once and a while. And it was LOUD. Try putting spacers on the small black bar underneath your car. You will know what i am talking about if you look under it.If someone has a pic of the underbody or knows what im talking about, maybe they can explain it better. I would put money on that being the problem.
Old Mar 27, 2008 | 08:31 AM
sleepyS14's Avatar
driveshaft problems.. aiisshh. get that thing on a lift ASAP!!
Old Mar 27, 2008 | 09:48 AM
slvevo8's Avatar
i have the spacers already, the exhaust system on the car is the one that was on it before I bought it, it fits fine, no clearance issues, it is a buschur system. I am almost certain it is the driveshaft bearings on the center section. They have alot of play in them, and they have been on the car for 78,xxx miles.
Old Mar 29, 2008 | 11:27 AM
slvevo8's Avatar
car went to the dealership, driveshaft is broken inside is what they told me. this is goin to be expensive...
Old Mar 29, 2008 | 11:38 AM
lonepatrone's Avatar
How was the dealership able to tell the driveshaft was broken on the inside? Are you confident in their diagnosis? If it's going to be expensive to fix, and if it is the driveshaft, why not go with an aftermarket shop for the repair?
Old Mar 31, 2008 | 05:28 AM
slvevo8's Avatar
i bought a warrenty from the dealership which i found out is void because the car is modified. the dealership sold it to me in error. the warrenty company will not warrenty a modified car, and i bought it that way. i figured the best bet for getting something worked out was to bring it to where i bought the car and warrenty. i am getting a full refund on my warrenty, and hey offered to pay half or the cost of repair, but i am holding out for them to pay it all.
zxac
Lancer Troubleshooting
15
Sep 29, 2015 01:04 PM
Jaxson75
Lancer Engine Tech
Jun 27, 2015 04:08 PM
reboundicon
Sep 23, 2011 05:08 PM
Jdmredline32
17
Jul 15, 2011 11:12 AM
NelloMorto
Dec 20, 2010 02:58 PM
