Evo Turbo Information
If only we could add compressor flow maps and max cfm's for each of the turbos listed, this thread would be complete ...
I did find this page which seems to have some mitsu compressor maps ...
link
link
I have a JDM evo and am getting a good deal on a JDM Evo 8 MR turbo from a friend. But someone told me that it does not have 10.5 turbine housing... is it true ??
Does someone have the exact spec of the JDM evo 8 turbo and JDM evo 8 MR turbo and Cams
Thanks
Thanks
i have this:
Evolution 3
Turbo = TD05H–16G6-7
Nozzle Area (cm2) = 7
Turbine = Inconel (steel alloy)
Compressor = Aluminium, 68mm wide
is it true that the most you will get out of it is about 15 - 16 psi??? if you manage to somehow get more boost you are likely just making hot air and making less power than you would at a lower boost since you are pushing the turbo way past its efficient operating range?
Evolution 3
Originally Posted by Blaster
i have this:
Evolution 3
Evolution 3
On 93 octane, I run 22psi. Works great.
Anyone know more about this turbo TD05HRA-16G6-9.8T - I just bought it and have installed it. seems to spool much quicker. However, how much max boost will it run and any flow ratings? charts? ect.
Btw anyone want to buy an EVO 6 turbo?
thanks.
thanks.
? Its the same one
