Cut up my stock UICP
Old Mar 26, 2008 | 01:19 PM
Burklow's Avatar
I'm just not feeling this mod.
Old Mar 26, 2008 | 01:24 PM
mdsevo06's Avatar
Should have just purchased the ETS LICP, might have saved you some time and money.
EvolNinja's Avatar
It's the cheap mod but costly when I have to get the other pipe back together. I painted the silver section gloss black so it matches. I'll take some pic when I get home tonight and post it back again.
Old Mar 26, 2008 | 01:33 PM
Nissan2Evo's Avatar
Originally Posted by EvolNinja
Yes the point is to increase the diameter of the inflow of hot air to the IC. I will be using T-bolt clamps and hopefully find a place to do the bead for the pipes. Do you guys know if there's any local shop that will do it?
lol...do you honestly believe you're going to gain anything from this..except for the headaches you're giving yourself. As another poster mentioned...should've just bought an ETS licp and been done with it.
Old Mar 27, 2008 | 05:12 AM
EvoDom's Avatar
bro dont waste the time...seriouslyy i have never herd of anything or anyo0ne even doing this....the LICP is made like that for a reason why are u putting the headaches on to get the pipe beaded, idk man my opinion leave it alone.
Old Mar 27, 2008 | 05:16 AM
urslo4n8's Avatar
man. thats a lot of effort cutting and beading.i und the reason to save money but hope it works for u
Old Mar 27, 2008 | 08:09 AM
EvolNinja's Avatar
If not, at least I still have the OEM LICP
Old Mar 27, 2008 | 08:28 AM
tony_b's Avatar
Have a welding shop throw down a small bead around it. Or you could try a JB Weld bead. I've head of people having success with it if prepped and done correctly.
Old Mar 27, 2008 | 08:33 AM
EvolNinja's Avatar
Thanks Tony
Old Mar 27, 2008 | 09:07 AM
chrisevo8's Avatar
Not a bad idea but you might be blowing pipes off left and right.
Old Mar 27, 2008 | 10:35 AM
Dapper Dan's Avatar
flare the end of the pipe and you will be fine......
Old Mar 27, 2008 | 11:44 PM
EvolNinja's Avatar
Went to a Race Fab shop and they can weld it together for $40. Good idea?
Anyways, here is the latest pic of the LICP. I'm probably going to bring the original end of the LICP and have them fabricate one to that same exact length and bend.
The pic you're going to see is side-by-side comparison.
hearnoevo
Feb 1, 2017 12:24 PM
2rbolag
Oct 2, 2016 01:00 PM
2rbolag
Sep 28, 2016 11:26 PM
pikkagtr
Jun 27, 2007 02:28 PM
eponti
10
Nov 7, 2006 11:40 AM
