More lightweight parts to keep the differential in place
Old Mar 28, 2008 | 09:05 AM
David Buschur's Avatar
We've been working on our new Side Differential Supports for quite some time. It took a few attempts to get them right.
Below is the picture of the stock side differential support. It is made of cast iron and has a rubber insert in it. We do offer an aluminum bushing kit to replace the rubber insert in the stock part. The stock cast iron piece weighs in at 4.5 pounds per side (9 pounds total). Here is what the stock part looks like:
This is what we've built to replace it. This new Side Differential Support bracket weighs in at only 2 pounds per side and is billet aluminum. This completely replaces the stock part and the need to replace the rubber bushing. Weight savings is 5 pounds. Here is what the new part looks like:
This is the new Side Differential Support bracket installed on my EVO:
The idea behind replacing the bushings is to keep the rear differential from being able to "twist" on the rubber mounts. This keeps the axles on a straight plain. The idea of doing the entire mount in a one piece billet aluminum design is to save the headache of pressing out the old bushing and to knock off another 5 pounds of weight.
Our Rear Diffential Bar (mustache bar) completely replaces the stock cast iron bar on the car, keeping the side supports and all factory mounting points. This bar takes 13 pounds off the rear, add to this our new side support bushings and you end up with 18 pounds off the rear end. You also end up with an overall stiffer package in the rear and a diffential that cannot move.
Old Mar 28, 2008 | 09:10 AM
Exciting News's Avatar
Is this priced yet?
Old Mar 28, 2008 | 09:12 AM
evo9 ate u's Avatar
might have to get me a pair of those
Old Mar 28, 2008 | 09:17 AM
dafunk630's Avatar
damn my parts list just keep on growing lol.
Old Mar 28, 2008 | 09:34 AM
deadbeatrec's Avatar
Old Mar 28, 2008 | 09:56 AM
Erik@MIL.SPEC's Avatar
How much more noise/vibration?
Old Mar 28, 2008 | 10:01 AM
EvoDan2004's Avatar
awesome.
now to the dumb question
can this be used without ur mustache bar ??
Old Mar 28, 2008 | 10:07 AM
Yes, it can be used with the mustache bar or without.
The pricing is $275 for the set.
Old Mar 28, 2008 | 10:21 AM
9sec9's Avatar
David, I want a set. I'll call. Now, I wonder how many 'other' shops will miraculously appear with a set too.
Old Mar 28, 2008 | 10:25 AM
caLi4G63's Avatar
very nice looking pieces. as stated above, is there a noticeable increase in vibration or noise? not that it should matter much since you always have to sacrifice for performance
Old Mar 28, 2008 | 11:17 AM
I have not driven the car yet with them installed. I am sure there is more noise/vibration with them but it isn't going to be anymore than the rear diff support bar and the aluminum bushings that were used before this part was developed.
Old Mar 28, 2008 | 11:25 AM
caLi4G63's Avatar
David, at what point would you say this should be something to be considered for EVO owners? would it depend on how much power someone is making? or is this just a good overall modification for EVO enthusiast? I'm sure some people would be bothered by the cabin vibrations and noise but I personally wouldn't mind the noise or vibration.
Old Mar 28, 2008 | 11:33 AM
11secEVO7's Avatar
I just got your diff support bar a couple days ago...
I'll have to get this as well..
will look out for it on your website
Old Mar 28, 2008 | 11:47 AM
vwjeff's Avatar
FOCK... you know sometimes I hate Buschur Racing. If it aint 1 thing its another with you guys.
Drop somemore weight with these aluminum beauties...
Dave I am loving the new mounts, GREAT job man
**EDIT** I was just thinking about when I put in my diff bar, those cast stock mounts were heavy as h*ll.
Old Mar 28, 2008 | 12:06 PM
I have no suggestion to when to add these. We did the mustache bar/aluminum bushings on our black car and after that our sixty foot times seemed to improve. This is going to add some vibration I am sure.
Unless you are concentrating hard on getting rid of weight I don't really see something like this being needed on a daily driven 12 second EVO, that's for sure.
