BOV replacement
Old Mar 31, 2008 | 08:52 AM
rartist's Avatar
BOV replacement
Sorry about the NB question. I just chased down a leak in my TB shaft, thats fixed. Now I hear the hiss coming from my stock plastic VIII BOV. I'm was going to replace it with a JDM MR aluminum BOV; is that good or is there something else I should go with? My 03 is a driver with a K&N drop in and a Dynoflash mail in, else stock. No extra $$$ for turbo back yet.
What should a healthy BOV sound like? I get a hiss under moderate throttle as the turbo spools, and the quick woosh on the clutch. WOT drops out somewhat and the throttle goes numb, hence the leak tests. Spool up is the pits.
Old Mar 31, 2008 | 08:59 AM
Smike's Avatar
Metal DV = good.
The WOT drop and numb throttle - flash. Not going to start the fight - but after dealing with friends car with DF mail in or BR stage flash...some pointes were less aggressive than the OE maps. After we sat down and reflashed the car was totally a new animal. Timing can also change spool up response.
Old Mar 31, 2008 | 02:14 PM
rartist's Avatar
Anyone else had issues with the Dynoflash mail in? I haven't tested it thoroughly, but it sometimes feels like 2/3-3/4 throttle is as strong or stronger than WOT. Once I get the BOV in I can mess with it more.
Old Mar 31, 2008 | 07:24 PM
Jeff_Jeske's Avatar
You best option is to get an EVO 9 metal DV. They hold boost solid to 26psi and can be had for less than $75.
Old May 5, 2008 | 08:55 AM
rartist's Avatar
Has anyone else seen this? I've cured my leaks, but the numb WOT still persists. 2/3 throttle is about as strong as WOT. I'm getting good boost, but the more I push it, the more it doesn't want to go.
Old May 9, 2008 | 10:01 AM
rartist's Avatar
bump
Old May 9, 2008 | 10:25 AM
recompile's Avatar
I've seen the "part throttle feels faster than full throttle" symptom before. Typically it means you have some room for improvement on your fuel map, and WOT is likely a bit rich.
Old May 9, 2008 | 01:52 PM
rartist's Avatar
Now my next question is what can I do about it. There's definitely room for improvement, the throttle feel disappears the more I push it. The more I give it, the more it doesn't want to go.
Do I walk away from what I have and go with someone else's tune, or can what I have be improved?
taylorgang
Nov 21, 2011 11:59 PM
Rough 01
Sep 6, 2010 08:40 AM
sir monster
17
Mar 27, 2010 11:18 AM
SpeedJunkyz
Jun 6, 2008 02:25 PM
twinkiemobile
Lancer Troubleshooting
Feb 26, 2004 09:22 AM
