Exhaust smell inside
I'm getting a strong exhaust smell inside the cabin only when I'm in boost 10+ psi at idle and normal driving I have no exhaust smells incabin. I had the megan manifold on the car which was cracked replaced with ported and coated buschur manifold I also went ahead and did o2 housing while I was at it. All new gaskets on the manifold to the head manifold to the turbo and o2 housing all torqued to spec. I've checked and re-checked and can not find a leak on the head side. So I'm thinking it's where the down pipe meets the cat. I also had the shop that did my fluid change check and they did not find anything. AFRs on the apexi narrow band are very normal 14-3-14.5 at idle so I don't think its head side. It does dip in 10.0AFR at full boost but I need a tune for that problem. It does have a HFC and espelier jsg500 exhaust.
Turns out to be the v-band clamp for the turbo I finally saw the soot buildup, I tried to tighten it down some looks like it worked itself loose. I'm going to try again later clean it off see if comes back or all is good.
Did it fix it?
don't mean to thread jack but is replacing the doughnut gasket recommended? i just re-used mine and haven't had a problem but i'm wondering if i should replace it...
Sanny632
Jan 3, 2011 12:31 PM
TwistedEvo8
15
Oct 4, 2009 05:58 PM
kyoo
10
Jan 15, 2009 12:05 AM
