***DTM T3 Twin Scroll Results for 83MM Turbo***
We finished up a PROTOTYPE T3 Twin Scroll Kit today.
The results were actually much better than expected. The manifold in raw form isn't that pretty as we are also experimenting with various runner lengths, but the results are still amazing. The turbo is a custom 83 MM EXDUCER in a T3 twin scroll turbine housing. The turbocharger will remain "nameless" for now with limited specs until we finish the testing. For now here are the list of mods and the dyno graph.
Stock 2.0
Stock Intake Manifold and TB
3" TB exhaust
DTM 3" FMIC
DTM TS BMF 83MM turbo kit
SINGLE 44mm TiAl Wastegate
Upper IC piping
Single Walbro HP 255
DTM 280 Cams
20 PSI, Stock injectors at 83 % duty cycle
Logs for The stock computer show full boost by 4500 rpm.
377 WHP and 302 Ftlbs uncorrected. The graph is corrected and shows 374 I believe.
Also testing will finish next week on the stock computer and 880cc Injectors.
Then we put in the AEM. The car is an 05 MR six speed.
Stock 2.0
3" TB exhaust
DTM 3" FMIC
Upper IC piping
DTM 280 Cams
Wow, that spools up nicely for a turbo slightly larger than mine, at least on the compressor side. Good work Nick! Pics of the manifold would be great.
Or is this the manifold that I have already seen?
