FULL-RACE TWIN SCROLL 35R test results and data
Old Apr 21, 2008 | 12:31 PM
  #46
EvoDan2004's Avatar
did a compression test. ''dry''
this was done on my car just after running it. it was hot
from left to right.
7 cranks = 170
5 cranks = 170
7 cranks = 170
5 cranks = 170
7 cranks = 170
5 cranks = 170
7 cranks = 175
5 cranks = 175
now im going to do a leak down test and check my head studs to make sure there trq'ed down still.
Old Apr 21, 2008 | 12:35 PM
  #47
EvoDan2004's Avatar
also should i do a wet test???
if so does the motor need to be hot or cold
and how much oil do i put in each cylinder
Old Apr 21, 2008 | 12:50 PM
  #48
leecavturbo's Avatar
Originally Posted by evodan2004
gutted???? my car? i dont know if your asking me or telling me. but my car is not gutted. only thing removed from it is the basics. spare tire, mini battery kit, front crash bar. other then that its all there. o and i take my floor mats out when i race. not for weight issues but because the driver one slides around and i dont want to be distracted.
the turbo kit its self weighs more then the stock one buy alot. so if anything the weight i saved i just added with the turbo kit.
lol, no dan over here we say "gutted" when your really upset/not happy
about something or luck is just not on your side
i found dry leak down test work best as you don't have the bubbling
sound of the air going through liquid when dry, so you can pin point
by listening to where the air is leaking. i.e if your inlet valves are leaking
you will hear air in the inlet plenum or filter. or exhaust if the exhaust valves
and in your sump breather if the rings are leaking bad.
Old Apr 21, 2008 | 12:58 PM
  #49
CBRD's Avatar
dan you need to bring your car down...
we just did 380-400 whp a few times with 50 trims, stock block with cams.. 22-25 psi on pump stock ecu... spool is great....
we saw an hta3076R last week that didnt impress me for spool...
id like to get yours on the dyno, to get some comparable numbers.
cb
Old Apr 21, 2008 | 01:15 PM
  #50
crcain's Avatar
I wouldn't have thought a leakdown test makes sense if the compression test comes up ok?
Old Apr 21, 2008 | 01:21 PM
  #51
HaVoC RR's Avatar
get down there dan! ill roll with u..
Old Apr 22, 2008 | 02:21 PM
  #52
EvoDan2004's Avatar
head studs are all at the trq settings i put them in as. so thats good. thursday i do a leak down test.
Old Apr 24, 2008 | 05:17 PM
  #53
EvoDan2004's Avatar
ok the leak down test is completed. everything is perfect. i have no issues at all.
so its a go for new mods.
1st up.
new cams
3.5 dp
and a cause im happy.
ill be starting the swaps next week.
Old Apr 25, 2008 | 06:58 AM
  #54
LilRico's Avatar
I'm got me some new cams too bro.. to us both!
Old Apr 25, 2008 | 08:53 AM
  #55
so the cause of the blue smoke bellowing out
the back is a mystery still?
go careful
Old Apr 25, 2008 | 02:09 PM
  #56
EvoDan2004's Avatar
go careful
careful??? dude. im a beet the **** out of my car till it explodes and i dont give a f#$k what happens till then. but untill then i like to know whats going on and how things are holding up. haah.
the smoke could of been from the 300mile cheese steak cruse we all took and well lets just say 65mph was not maintained. so it could of been some blow buy or from the p.o.s gas station i had to fill up at. i normally only use sunoco gas but i had to fill up at a no name junk station cause i dident think i would make it to a sunoco let alone know where the next one was. so it could of been bad gas i guess. i have no clue really but the motor is perfectly fine and is really for another sh!it kick beating. lets do it.
Old Apr 25, 2008 | 02:53 PM
  #57
rock n roll dude
Old Apr 25, 2008 | 09:34 PM
  #58
Blkstreak's Avatar
Nah, we were just cruising the whole time. hehe.
Old Apr 26, 2008 | 02:32 PM
  #59
gamebred26's Avatar
dan you going to island tomorrow?
Old Apr 26, 2008 | 02:34 PM
  #60
EvoDan2004's Avatar
95% probly yes
