royal purple 75-90
Old Apr 16, 2008 | 06:33 AM
ohEVO18's Avatar
royal purple 75-90
anyone on here have any opinions or reviews of this gear oil? Just asking because a buddy put this in his M3 last night and noticed an immediate and huge difference. wanted to get some opinions...
Old Apr 16, 2008 | 07:21 AM
RX73Rotorj's Avatar
I know when i had my talon the guy before me had royal purple in it and i changed it immediately to mobil 1 and felt a amazing difference. I will NEVER put royal purple or penzoil in my cars ever...
Old Apr 16, 2008 | 07:23 AM
RX73Rotorj's Avatar
thats odd so all of those posts in the newbie forum didnt count hmmm. But anyways that my 2 cents with lube oil.
Old Apr 16, 2008 | 08:19 PM
Oil Doc's Avatar
http://bestoil4you.com/files/g2457GearLube.pdf
Read that link... It is a series of tests performed by several of the Top Testing Facilities in the US
Royal Purple doesn't fare too well... of course, not much that Royal Purple makes does..
Doc
Old Apr 17, 2008 | 05:31 AM
Jackson Machine's Avatar
We've done a lot of testing and seen considerable gains in switching to Royal Purple from conventional, Amsoil, Red Line and Mobil 1.
Old Apr 17, 2008 | 05:40 AM
SparkTech's Avatar
I've used Royal Purple for years without any oil related failures. The Pro-stock motorcycles run it and they turn insane rpm's
Old Apr 18, 2008 | 05:04 PM
Oil Doc's Avatar
Take a look at Royal Purple's results in a 20 Hour Shear Test Located on Page 6
www.bestoil4you.com/files/g2457GearLube.pdf
They can't even stay in Grade when they start out at a higher Viscosity than other lubes.
Some things to consider... I can sell you an additive for your oil or gear lube that will lower oil temps and provide you with more HP.... GUARANTEED !!
Will you buy it ??? Some people will blindly buy that additive and it does what it says.... What they don't tell you is that it causes excessive wear and your oil breaks down faster..
Think of why you don't see advertised on TV anymore: Pro-Long, Motor-Up, Dura-Lube and the others.. They were sued by the FTC and lost... Great claims, false advertising..
Doc
Old Apr 18, 2008 | 05:22 PM
wshihdnevo's Avatar
i have it, and its great when up to temp, but sucks when colder. I will be going to redline shock proof, Oil Doc, been trying to PM you and havent gotten a return reply at all...
Old Apr 19, 2008 | 12:49 AM
SHIFTT IX MR's Avatar
Oil brands are like cell phone companies; eventually you get around to sampling each. this is my case, and after i have tried them all my car simply responds better to royal purple. From motor oil to gear oil.
Old Apr 19, 2008 | 07:54 AM
Oil Doc's Avatar
I have no PM from you... just went and checked...
If you are going to use Redline, Do No use Shock Proof, it has a tendency to build deposits. Use MT-90... Not MTL.... MT
I am going to send you a PM just for contact.. Please reply just so I know...
May have had something to do with me being Suspended for a day ... LOL
Doc
Old Apr 19, 2008 | 07:57 AM
sabastian458's Avatar
personal experiance thru 2 friends. VERY BAD. Granted it was engine oil, but still. The both withing 2 oil changes had fatal engine failures due to the oil. Both were rod bearing knock.
Old Apr 19, 2008 | 08:49 AM
Oil Doc's Avatar
There is a 3 Sequence test for Shear on oils. The RP that was tested, sheared out of Grade at the end of the first sequence.
What does this mean ? It means the oil thinned out below it's advertised Viscosity Grade.... ie: The 10W-40 that was tested ended up a 30 wgt 1/3 the way through the test..
See where RP Gear Lube ended up .
http://www.bestoil4you.com/files/g2457GearLube.pdf
Doc
Old Apr 19, 2008 | 08:55 AM
OldschoolEVO's Avatar
Originally Posted by Oil Doc
very interesting read btw
Suarez11mx
Sep 25, 2014 02:43 AM
PlanoEvo
32
Jul 20, 2011 10:49 AM
newmitsuowner
Mar 26, 2011 04:19 AM
OZRaLLyDJ
Mar 19, 2005 04:58 PM
WildOne
Jul 14, 2004 05:43 AM
