ams gt35 r turbo gasket/sealant questions.
hey i am a noob to ams's gt35r kit. i contacted them about a gasket to go between the 5 bolt turbo outlet and the o2 housing.they said they donot use a gasket but some copper gasket maker???the highest temp stuff i have found anywhere is only 700deg.am i missing something or whats going on with that?thanks for help
a very little amount of exhaust sealant will be sufficient.
after first fitting and a few heat cycles re-check the bolts
are tight , after the third time you check them you should
have no further issues
D1andonlyantman
Feb 28, 2017 01:32 AM
DarkEvo
Nov 19, 2012 10:59 AM
AKgambler47
Mar 14, 2008 04:24 PM
