Official HTA EVOGREEN thread by FP
Here is a UK company that does the Green with BBs, 4 inch shroud, ceramic coating etc.
http://www.turbodynamics.co.uk/downl...reenTurbos.pdf
We all want the same spool as stock with more air....but isn't that impossible?
You need bigger wheels, bigger hotside etc. so more weight and thus inertia=more lag and lower threshold.
I am just an amatuer, but in my opinion you can only get same spool and more air if you change the material for the turbine, shaft and compressor into titanium(and ofcourse a perfect match between turbine/compressor).
That way you can use bigger wheels and hotsides, which you need for more flow, and get the same spool because of the low weight /inertia of the internals.
Add some BB's as an option and call it a FP Evo Rainbow!
For interia as you said F = ma = PA. So if you hold a constant pressure P (exhaust pressure from the engine) and increase A (surface area of the turbine blades) such that it is linearly proportional to the mass of your new rotating parts, m, then your radial acceleration would be a constant, a, and you would have the same "lag". Basially you have a = PA/m. Also, you can flow more air and hold the same pressure if you increase your flow rate, and the area (say from 9.8 to 10.5 for example) which is the whole point of upgrading the turbo in the first place.
Somebody correct me if I missed something here.
I was kind of bored this morning so I thought I would think about this and I think if you increase the surface area of the turbine blades proportional to the rotating mass of the new components then the radial acceleration of the rotating mass will remain constant.
For interia as you said F = ma = PA. So if you hold a constant pressure P (exhaust pressue from the engine) and increase A (surface area of the turbine blades) such that it is linearly proportional to the mass of your new rotating parts, m, then your radial acceleration would be a constant, a, and you would have the same "lag". Basially you have a = PA/m. Also, you can flow more air and hold the same pressure if you increase your flow rate, and the area (say from 9.8 to 10.5 for example) which is the whole point of upgrading the turbo in the first place.
Somebody correct me if I missed something here.I'm humbled! LOL
Josh
Here is some info from Wikipedia (very good info on turbo's there btw):
A lag is sometimes felt by the driver of a turbocharged vehicle as a delay between pushing on the accelerator pedal and feeling the turbo kick-in. This is symptomatic of the time taken for the exhaust system driving the turbine to come to high pressure and for the turbine rotor to overcome its rotational inertia and reach the speed necessary to supply boost pressure.
Lag can be reduced by lowering the rotational inertia of the turbine, for example by using lighter parts to allow the spool-up to happen more quickly.
Another common method of equalizing turbo lag is to have the turbine wheel "clipped", or to reduce the surface area of the turbine wheel's rotating blades. By clipping a minute portion off the tip of each blade of the turbine wheel, less restriction is imposed upon the escaping exhaust gases. This imparts less impedance onto the flow of exhaust gases at low RPM, allowing the vehicle to retain more of its low-end torque, but also pushes the effective boost RPM to a slightly higher level. The amount of turbine wheel clipping is highly application-specific. Turbine clipping is measured and specified in degrees.
I think it's interesting to look at what FP is selling to the subie folks as the HTA Green:
http://store.forcedperformance.net/m...Code=WRX-Turbo
On this page you'll see thumbnails for a GREEN and a GREEN HTA. Also notice the prices. Anyway, the subie GREEN HTA delivers "over 56lb/min without an increase in turbo lag". That's much bigger than what Robert was talking about in this thread initially. Hmm, over 56 lbs/min, sound familiar? Take a look at the pictures. What you can see of the compressor wheel looks just like the 3076HTA which flows about the same. A compressor like this could be "almost too big to call a Green".
Gary
Gary
The Subie HTA Green pushes 56lbs per min, the FP 3076 HTA for the EVo pushes 57, these would be a better comparison for capacity. The subies displacement is 2.5 litres so the comparison is not exactly the same.
While what you are saying is essentially correct, there are two issues that affect at what rpm a turbo reaches a given boost level - one is the design of the turbo, and the other is lag. The first is the trade-off between at what rpm a turbo reaches the desired boost vs. when it runs out of capacity to maintain that boost at high rpm. The other is if a turbo cannot respond to changing input from the engine due to inertia.
I'm guessing here, but I think the HTA version is a standard green with a clipped wheel?
PS: Wikipedia has definitions posted by whoever so you can never really trust it as a reliable source. Take it all with a grain of salt and if it makes sense then go with it. Here what they have posted seems to be true but in general all definitions on that site are posted by guys like you and me so I would never trust it as an accepted source of information like a published encyclopedia or something like that.
But with that all said I agree with you. Good stuff here. Food for thought if nothing else.
I stand corrected; so what is the relationship between a "green" and an "HTA green" then (since the name seems to imply they are related somehow)?
Since the HTA Green has not been released, it would be difficult for anyone but FP to answer your question.
If it's an HTA, though, it will have a different and unique to FP "HTA" compressor wheel.
You can see the mods for the current Green on the FP webpage.
If it's an HTA, though, it will have a different and unique to FP "HTA" compressor wheel.You can see the mods for the current Green on the FP webpage.
By the way the FP GT3076HTA is not specifically "for the EVO". It is a normal rotation turbo with Garrett GT30 turbine and a T3 turbine inlet, so it is for anybody who wants to do the whole T3 thing.
The Subie compressors are also normal rotation. So it's not like FP already had an off the shelf wheel ready to go into the evo 9 turbo to make this "larger variant". But it would have been pretty simple if these wheels are cut from billets on a CNC milling machine from a dataset, like the "regular" evo green wheel is. Press the button that says "transform - mirror" and presto, you are well on your way to a dataset for the reverse rotation version of the wheel (for the evo).
The billet wheels are one reason why these turbos are kinda expensive. They are not just stamped out like friggin cookies. After looking at prices on turbos from HKS, Greddy, and some of the other specialty turbo shops, I gotta say FP is doing a great job combining high technology and performance with reasonable prices...
Gary
