newbie cam question
Old Apr 19, 2008 | 12:15 AM
alloutDSM's Avatar
newbie cam question
i have a gt35r but its dynoing at around 350? at 22 lbs anyhow i have the stock cams but want to upgrade so i can get into the 450 range what do you think would be the best cam for me? also what do i need to change the cams is there anything else that must be done to support this? thank you!
Old Apr 19, 2008 | 12:19 AM
AJsGenerX's Avatar
272s I think would be sufficient. I dont think you can gain 100 whp with just cams though. If you're looking for something thats not really suitable for daily driving, 280s would be better. GSC is a good choice for cams.
Old Apr 19, 2008 | 12:42 AM
SOEuro's Avatar
GSC S2s...get them
Old Apr 19, 2008 | 12:44 AM
alloutDSM's Avatar
well the car already has a gt35r with turbo back exuast/770 inj and well other supporting mods ie intake and so on im pretty sure i can get atleast 400-450 on that gt35r but with the stock cams its not looking good also tho motor has an 8.8 to 1 compression
Old Apr 19, 2008 | 08:09 AM
2theMAX's Avatar
You should be able to achieve atleast close to your goal WITH the stock cams by turning up the boost (and tuning).
Old Apr 19, 2008 | 08:13 AM
GregGSC's Avatar
if the car has the supporting mods a set of S2 cams will more than likly get you right in the 430-480 range. ive seen it many time.
Old Apr 20, 2008 | 01:41 AM
alloutDSM's Avatar
ok well i ended up getting hks cams and gears i have the gt35r at 22lbs and 770inj it dyno'd in at 376 does this sound about right? should i turn boost up how much do you think i could handle thanks for the help!!!
Old Apr 20, 2008 | 01:43 AM
alloutDSM's Avatar
also did a tune on 107oct at 430hp to me these numbers just seem low???
Old Apr 20, 2008 | 07:28 AM
heltzelfitness's Avatar
what other mods do you have? b/c that would me some key info to know before suggesting a cam upgrade... b/c if you have an upgraded fuel system, cams will do little for HP gains if you're engine isn't getting the required fuel needed...
Old Apr 20, 2008 | 07:29 AM
be careful of turbo spiking when increasing boost... you can do some internal damage... (learned the hard way)
Old Apr 20, 2008 | 09:08 AM
alloutDSM's Avatar
well i also have 770 inj fuel, rail, fpr, turbo xs fmic, new fmic piping, turbo xs rfl bov, custom turbo back exuast, hks cams and gears and im at 22lbs oh yeah and the had the ecuflashed but it still dyno'd 376 wtf!!!?
evotuner04
Sep 15, 2014 07:55 AM
jimmcfeely
Aug 30, 2014 06:00 AM
brusinn
Mar 26, 2014 09:23 AM
honki24
Dec 20, 2006 09:43 AM
PHILLY EVO
63
Feb 25, 2005 03:40 PM
