506whp Stock IX turbo E85
Old Apr 21, 2008 | 11:23 AM
  #61
Import Junky's Avatar
I was thinking of an hta35r, what do you think of this with a 10:1 motor like yours Lucas?
Old Apr 21, 2008 | 12:32 PM
  #62
JohnBradley's Avatar
Originally Posted by wshihdnevo
^Lucas if you want you can either have mine, its the Megan tubular, for your ported stocker, unless Aaron wants to donate his uber jdm piece to you. Let me know though as I would do a straight trade to you if interested?
I was gonna offer that HRS and put the ported stocker on I think to see if I can get some spool back...Spool that Lucas' honestly doesnt need. The car is an aboslute beast on the street.
Old Apr 21, 2008 | 12:52 PM
  #63
EvoRecordSetter's Avatar
Originally Posted by Ted B
The optimum shift points are:
1-2 Right around 8000rpm
2-3 7200rpm
3-4 7200rpm
4-5 7200 rpm
ted do you have a program or something that gives you this information? or did you just glance at the chart and have your brain do some math and come up with those like i did?
cause there technically is a right shift point if you have the gear ratio's and a detail hp / tq chart for each RPM so you could probably do it right. just curious the way you came up with those numbers.
Old Apr 21, 2008 | 12:57 PM
  #64
I doubt this is the one Ted uses, but there are several programs out there such as this one:
http://www.bgsoflex.com/shifter.html
I have one that also calculated other important information such as overall speed per gear, speed per 1000rpm, tire size, etc.
Old Apr 21, 2008 | 12:58 PM
  #65
slicedbreadno2's Avatar
Very nice numbers congrats.
Old Apr 21, 2008 | 04:25 PM
  #66
Lucas English's Avatar
I think on E85 or race gas the 10:1 and a HTA35r would be great. My car may get a HTA35r by the End of the year. With my high comp experience so far on a EVO the only bad I see about its trying to run pump gas and the high comp. The higher comp motor is new thing for me so I may have a different opinion in a few years about it.
Old Apr 21, 2008 | 04:40 PM
  #67
wshihdnevo's Avatar
Werd
Old Apr 21, 2008 | 06:30 PM
  #68
Mellon Racing's Avatar
nice pics, man what a sleeper haha, if those IC pipes were black with black couplers you could sucker fools around here left and right $$$$
Old Apr 21, 2008 | 06:31 PM
  #69
Thanks for your response Lucas. I won't be doing my engine build until I run the HTA35R for awhile. When I do though I would like to entertain this idea and hopefully have my daily driver by then....
Old Apr 21, 2008 | 08:23 PM
  #70
brp's Avatar
brp
thanks for the reply. i am definitely keeping an eye on this thread. so far i made 405whp and 430tq on the stock motor/turbo on the E75 winter mix we had here, but that was before the new intercooler and before the ported ex. manifold, in. manifold and t/b and the new tune i been working with along with JustDSM.
nice work, congrats!
Old Apr 21, 2008 | 08:41 PM
  #71
SuPeRNeT's Avatar
What it like to tune the higher compression motor? less timing every where or can you keep the timing the same as the old motor?
Old Apr 21, 2008 | 08:49 PM
  #72
evoPirate's Avatar
+1 on that, I've always been interested in higher compression for the evo
Old Apr 21, 2008 | 09:43 PM
  #73
mchuang's Avatar
Great numbers on a 9 turbo. I can only imagine what you can do with the fpgreen. What diff are you using for your 04?
Old Apr 21, 2008 | 11:35 PM
  #74
Well on the E98 my timing # are still quite crazy high with no knock. I have another cust here with 10:1 on E85 and the timing # are not much different. I also did a gas tune on that cust car on 92oct at 20psi and he is a good 3deg lower then most evos at the same boost.
I have a '05 diff in the car.
Old Apr 22, 2008 | 10:24 AM
  #75
ETS Michael's Avatar
This is a seriously impressive milestone Lucas, congrats to you and the crew! Thanks for posting the pictures Billy, almost as good as having been there
Tom
