Big cams little Turbo
Old May 28, 2008 | 10:44 AM
  #61
ETS Michael's Avatar
Great stuff Aaron, thanks for sharing your results! I've been using yours and Lucas' advice from this testing regarding cams for my recommendations for quite some time now
Tom
Old May 28, 2008 | 12:06 PM
  #62
GregGSC's Avatar
fyi the mivec is hard at work and is the reason you guys arent loosing bottom end, i don't see an evo 8 responding the same as these 9s have.
Here is a graph of an S3 vs S2 on a 35R evo 8, you can see the spool time difference... ie the give and take of a big cam on a small turbo.
Old May 28, 2008 | 01:22 PM
  #63
bnice01's Avatar
I dont know Greg but the gm 3port did its job on this VIII (jhanksevo)LOL
The base line in this DLL was using HKS 272's, stock VIII turbo 28psi tapering to 26-25psi, 100% meth, gm3port & supporting mods. (New power) was upgradeded with your s2's, IX turbo 28psi (holding the whole pull), 2-3* less timing, and ETS LICP. All pulls done on the same road during night hrs. Even my butt dyno says this shizzle comes on HARDER LOL. These cams are the HEAT, I need to get me set ASAP but I'm leaving for gunner school.
Old May 28, 2008 | 01:30 PM
  #64
FathouseFab's Avatar
Anybody run the fp4r's on a stock turbo 9 yet? I keep changing my mind on which cams to get.
Fathouse
Old May 28, 2008 | 06:26 PM
  #65
bnice01's Avatar
Originally Posted by SOEuro
i took an 03 evo to the track yesterday with S2s and a STOCK IX turbo...and it dropped .3 seconds in the 1/8th since upgrading from HKS 272s
i love the s2s on stock turbo
you cant drive j/k , let me drive jhanksevo's car I'll show you whats up
Old May 28, 2008 | 06:37 PM
  #66
evo8fate's Avatar
Originally Posted by wshihdnevo
You obviously have done other mods along w/ the 280's since your 319, cause there is no way you picked up 61 whp from just cams...
the only other thing i did was tuned and a front mount that was it.
Old May 28, 2008 | 06:42 PM
  #67
ApacheFixer's Avatar
I have S2s my 03, stock turbo, 9.8cm hotside and i love how these cams run. With the minimal mods as seen in my sig and florida weather (80deg and 90% humidity) i ran a 109 and 110mph trap. The car idles nicely and noticed only a minimal drop in spool.
Old May 28, 2008 | 07:23 PM
  #68
sparky's Avatar
Originally Posted by ApacheFixer
I have S2s (in) my 03..... noticed only a minimal drop in spool.
Apache: Did you go from stock cams to the S2's?
Old May 28, 2008 | 09:01 PM
  #69
JohnBradley's Avatar
I almost forgot about this thread...good to see the small turbo big cam love is still going. Interesting info Greg as always.
Old May 28, 2008 | 09:58 PM
  #70
Turbo Kyle's Avatar
John, would you reccommend M3's on a IX with a stock turbo? I am doing springs so I was thinking about just going with the M3's. I will be running E85. My goal is to max out a FP Green on E85
Old May 29, 2008 | 01:10 AM
  #71
wshihdnevo's Avatar
^I know Im not JB but I think those cams would be nasty w/ what you want to do and would be a great setup, especially on E85
On pump...? its kind of hard to believe...proof...?
Old May 29, 2008 | 01:40 AM
  #72
RazorLab's Avatar
Have a log to back up that claim? holding 28 psi on a stock turbo is very unlikely, even on a FPgreen it is very unlikely.
Old May 29, 2008 | 01:59 AM
  #73
ineedparts's Avatar
uhh... 500 on stock ix turbo? is that POSSIBLE?
Old May 29, 2008 | 05:48 AM
  #74
bnice01's Avatar
I'll get you a log soon, I dont have it on my laptop anymore this happen back in april. me & jhanksevo are in the military work two different shifts. I dont see how its unlikely with a high lift profile cam but I do remember the wga duty @ 6500 and on was 100%.
Old May 29, 2008 | 05:50 AM
  #75
RedLanEVO's Avatar
I have S2 with a Green. Made 350whp at 19psi tapering to 17psi. So basically stock boost with big cams. They don't make you lose power.
