Mustang dyno load = street load?
Old May 4, 2008 | 03:51 PM
  #91
RazorLab's Avatar
Here is another overlay. This time a customers car. On and off the dyno same day.
I put the hammer down on the street a little later than the dyno but after that it pretty much lines up everywhere to the dyno.
Notice that the WGDC curve is identical between the two, meaning ecu-boost error correction did not have to kick in to hit the target load on either the dyno, or the street.
Old May 4, 2008 | 04:49 PM
  #92
9sec9's Avatar
Nice job razorlab. I think you must have the dyno dialed in too. Now, if I could only get my own, I'd be happy.
Old May 4, 2008 | 08:40 PM
  #93
dbsears's Avatar
Bryan, is that graph using your boost pill or a GM 3port? I would assume its a 3port because the WGDC aren't maxed out. That curve is just so smooth.
Old May 4, 2008 | 09:56 PM
  #94
RazorLab's Avatar
It's a 03 with cams/TBE/injectors/pump/etc at 22.5psi using a GM 3 port with load-target based ecu-boost.
Old Oct 9, 2008 | 07:53 AM
  #95
ZWingerRyRy's Avatar
Doesnt Dynojet mostly tune your car at WOT? For what i've heard
Old Oct 9, 2008 | 08:48 AM
  #96
TTP Engineering's Avatar
Dynojets are driven on. Tuners tune cars.
Dynojets front and rear rollers roll independently, are not loaded to simulate real street load and your tune could vary from street to dyno.
Old Oct 9, 2008 | 03:28 PM
  #97
03whitegsr's Avatar
Razorlab,
Would you be willing to do a time based comparision instead of RPM based?
I think it would be more reviling of how close the two load situations are as it would clearly show if the RPM curves overlay or diverge from each other.
Old Oct 9, 2008 | 03:32 PM
  #98
CBRD's Avatar
isnt it awesome to think of the differentials working to send power back and forth? lol
cb
Old Oct 9, 2008 | 03:33 PM
  #99
Erik@MIL.SPEC's Avatar
I don't know about the Mustang, but for all the bad press DynoJets get, here's an interesting piece of info...
Aby has logs from his car on a DynoJet424x. The rollers together are approximate in weight to the Evo. He has an rpm vs. time trace when he was tweaking his AEM. The trace correlated really closely to his street logs...so close in fact he didn't need to adjust his tune IIRC.
If he wants, he can jump in here with specifics.
Also, I have personally had my car tuned by Bryan (Razorlab) with the Mustang Dyno in this thread. The tunes are spot on, and the MD is reflective of the load the car sees on the street.
Old Oct 9, 2008 | 03:52 PM
  #100
03whitegsr's Avatar
I have no idea how they all compare to be honest and I can see each side of this arguement compeltely. I would like to add though so I will just add a few things I have noticed.
On a dynojet, boost came on ~700 RPM later then it did on the street while tuning a 3000 pound GT42 powered subaru. This was the 424 dynojet with the single eddy current load (not used).
The lack of the rollers being tied together on the dynojet really pissed of the Subaru center diff on decel. I would imagine the ACD would respond similarly?
That same car ran like complete crap first time down the track. WAY too rich. A/Fs went from low 11s ont he dyno to high 9s. However, I changed the acceleration correction in the Hydra, retuned on the same dynojet and the next time at the track, the A/Fs were spot on in every gear. I beleive that if you are tuning on a dynojet and you hit the track only to find the A/F has changed, it is because the tune was wrong and not because of the difference in load. If the tune is correct, the load should not matter because the tune should be able to account for varying load.
On the mustang dyno, I was able to run 2-3 more PSI of boost on 91 octane then what I could get away with on the street. This was in 2WD mode on a 2G GS-T with the knock sensor disabled. Running the dyno tune that was safe on the dyno resulted in detonation on the street.
Either the DSM AWD system really sucks out power, or the Mustang dyno reads very different in 2WD vs. AWD. Two friends with similar cars/setups. '95 TSI AWD went 123mph at 3400 pounds, made 380 WHP. '97 GS-T went 122mph at 3000 pounds, made 450 WHP on the same dyno with the same dyno operator running it.
Old Oct 9, 2008 | 04:44 PM
  #101
The older non-424x Dynojets take A LOT longer by time comparison to spin the rollers. A customer has tested them and datalogged them by time.
razorlab
Mitsubishi TC-SST Discussion
Feb 8, 2011 07:17 PM
Bugermass
Mar 6, 2010 10:15 PM
razorlab
Apr 24, 2008 04:17 PM
brodienuchies
Aug 20, 2007 07:51 PM
David Buschur
Aug 26, 2005 08:24 AM
