What's the maximum Reliable RPM Limit on the 4G63 Head
DAM, should make for one hell of a ride!!!! What the minimum weight in the class that it runs in?
Thanks for posting the pictures, its great to see what others have created
I havn't seen Dover in about 18 years
Please check into the lifters, it the only weak link I could think of with your head. I would hate to hear something happened, sounds like you have a fun racecar.
keep use updated
Duncan
The 4G61T came in the late eighties Mitsubishi Mirage. It is a 1595cc version of the 4G63T. The block is identical to the 63. The big differences being the deck height is shaves 6mm. In addition the stroke is 75.5mm as opposed to the 63's 88mm. The bore is 82.5mm stock. This yeilds a far superior rod ratio to the 63. The rods and cylinder head are interchangeble with the 63.
My setup:
Custom 83.5mm 10.0:1 Ross Pistons
Carillo Rods w/ ARP Fastners
ARP Head Studs, Mains, etc
MLS Head Gasket
Brian Crower Stage 3 Cams
Ferrea Dual Interferance fit Springs, w/Ti Retainers
Adjustable Gears
DNPerformance Tubular Header
FP3052 Turbocharger
Ferrea 1mm OS Valves
Extrude Honed Stock Intake Manifold
Ported and Polished 1g Head
Fluidampr Harmonic Balancer
Custom Moroso 3-Stage Dry Sump Kit
Evolution 8 Intercooler
Haltech E6X ECU
My setup:
MLS Head Gasket
Adjustable Gears
FP3052 Turbocharger
Haltech E6X ECU
mark c, how much power are these 1.6ltr engine making?? is there any reason you want to stick with the 1.6 as oppoised to streching out to 2.0 or even 2.4ltr??
aslo what cars can you find these engines in??
Cheers
Chris.
PS the jamaican rally is amazing! i will go there oneday!
Cheers
Chris.
I've taken high speed video on OEM hydraulic lifters to almost 13k with no problems. I didn't take it higher than this, but I don't think the lifters would have any problems at all until the valvetrain went into float.
Depending on the cam profile and valve accelerations, rocker tips start getting angry and wearing badly by 11k.
Kevin
Kevin
Cheers
Chris.
Cheers
Chris.
R/TErnie
80
Jan 7, 2021 02:46 PM
Smogrunner
Apr 13, 2004 06:58 PM
