Limits/Stationary Rev Limit/
Old May 29, 2008 | 03:10 PM
EVO8emUp's Avatar
I tried changing this value from 5,500 RPM to 4,500 RPM.
Nothing happened.
Then I changed it to 2,000RPM so I didn't have to rev it so high to test it. Nohting changed.
It can't be the clutch switch as you still have to depress the pedal to start it.
Any Ideas?
This is the maximum RPM w/ the clutch pedal depressed, right, or am I interpreting this wrong?
Old May 29, 2008 | 03:20 PM
FathouseFab's Avatar
Does it always go to 5500, or does it just go to the rev limiter?
Old May 29, 2008 | 03:29 PM
EVO8emUp's Avatar
I'm glad you asked that. It doesn't even stop at 5,500. I didn't take it as high as the rev limit which was never changed.
Old May 30, 2008 | 11:31 AM
EVO8emUp's Avatar
OK, something funky is going on. I reflashed my stock ROM to the ECU and it still doesn't work.
Old May 30, 2008 | 11:34 AM
MR Turco's Avatar
do you have your clutch in, are you rolling?
Old May 30, 2008 | 11:37 AM
TouringBubble's Avatar
Do you have the ROM with the incorrect limiter definition?
Old May 30, 2008 | 12:17 PM
4kinboost's Avatar
Try an ecu reset,,, It worked for me.
Old May 30, 2008 | 12:22 PM
MR Turco's Avatar
its not windows, it really shouldn't NEED a reset.
Old May 30, 2008 | 03:56 PM
JohnBradley's Avatar
There is something wrong with your top clutch switch. The two step doesnt work off the bottom switch. Do you have an alarm or turbo timer?
Old May 30, 2008 | 09:19 PM
tephra's Avatar
+1
Old May 31, 2008 | 07:24 AM
EVO8emUp's Avatar
Clutch is in, not rolling.
I re-flashed the ECU with the stock ROM.
I do have a timer. I also think it's something mechanical. It doesn't make sense that the factory ROM would have the same problem.
I'm heading to the garage not to start trouble shooting.
I'll let you know what I find, FFR.
Old May 31, 2008 | 07:50 AM
tephra's Avatar
mate - look under the dash at the top of the clutch pedal.
1) make sure the switching is connected
2) make sure when the clutch is OUT the switch is pushed IN...
Old May 31, 2008 | 01:37 PM
EVO8emUp's Avatar
Found it!
I checked switch on the pedal and made sure it was functioning properly. It was.
There was a pin that was slightly popped out of the harness on the Vehicle Speed Sensor (VSS) on the back side, top of the transmission. The odd part was that I never received a CEL.
Popped the pin in, now it works perfectly
Thanks to everybody that responded with the replies. The help is greatly appreciated.
Roger
Zer0_13
Aug 6, 2017 04:27 PM
bbong
Jun 11, 2017 05:25 AM
Teal2nnr
13
Jul 9, 2016 04:21 PM
Evo9_Dubai
13
May 24, 2016 01:42 PM
jasburbak
May 20, 2007 09:08 PM
