Boost to high?
Old Apr 27, 2008 | 02:26 PM
mx4life85's Avatar
Boost to high?
I got my car tuned for the first time yesterday, and these are the parts that are installed:
Ebay TBE (with stock cat)
K&N Drop In Filter
Walbro Fuel Pump
Forced Performance 18lb Wastegate
So long story short, we put on the wastegate and fuel pump yesterday, and my friend takes my car out for a spin to tune it. He says that the boost is reading (on ProSport Mech. Boost Gauge) around 24psi with a boost spike of 30psi real quick. He said that he tuned it so I should be able to run with the boost like that, but 30psi boost spike worrys me. He said my A/F was around 12 and that I had pretty much 0 knock at all. Its smooth as can be and its insanely fast.
This is my DD, so I'm not trying to blow it up in a week. What do you guys think?
PS- I didn't think that the wastegate would get my boost up that much, I don't even have a boost controller or anything to raise it, so it much of raised it with the wastegate.
Old Apr 27, 2008 | 03:35 PM
mx4life85's Avatar
anyone?
Old Apr 27, 2008 | 03:40 PM
Sky Evo X's Avatar
Depends on how accurate your boost gauge is.
30psi is too much on pump. Your A/F at 12 is also lean.
Who tuned it?
Old Apr 27, 2008 | 03:46 PM
mx4life85's Avatar
It may not be around 12, I can't remember exactly what he said since I didn't know what the hell he was talking about. All I remember is that it was between 11-14ish.
And a guy named Kacey tuned it. He has tuned about 20 evos from around NC, and a few from this forum.
mx4life85's Avatar
Also, would getting my car tuned make my engine run alot hotter.
It seems that my car's engine is alot hotter now, and it seems like the fan runs alot more now, even when I'm not punching it.
Old Apr 27, 2008 | 03:59 PM
ethan169's Avatar
i am most certainly no expert. but i am almost certain that 30psi with pump gas is NOT safe. of normal even. 24psi also i think is kind of high for an average.
just my thoughts. but your gonna need some more opinions. and figure out what the a/f is. I assume your using a wide band o2 sensor.
-ethan
Old Apr 27, 2008 | 04:05 PM
RevMoto's Avatar
i would definitely lower it. You should be spiking 24lbs and tapering to around 20-21
Old Apr 27, 2008 | 04:11 PM
mx4life85's Avatar
Alright, so if I don't go into boost at all this week until I get it fixed, It won't hurt my engine right?
And also, when you get your car tuned, does it make your car hotter because my cars engine bay is insanely hot. It was hot before, but now its really really hot hah.
Old Apr 27, 2008 | 04:20 PM
RevMoto's Avatar
Your egt's got higher.
Old Apr 27, 2008 | 04:22 PM
mx4life85's Avatar
Is that something that is expected, or should I tell my tuner to look at that.
Old Apr 27, 2008 | 04:27 PM
RazorLab's Avatar
If there is too much preload on the Actuator it can spike like that. Try taking some preload out.
Are you still running stock boost control?
Old Apr 27, 2008 | 04:52 PM
mx4life85's Avatar
I'm still runing the stock boost controller, and yeah there is too much preload on the actuator. I just can't beileve there was enough so that I was running 24lbs of boost though.
Old Apr 27, 2008 | 05:04 PM
RevMoto's Avatar
I would just put your stock wga back in, they work fine.
Old Apr 27, 2008 | 05:05 PM
mx4life85's Avatar
The whole point in me using the aftermarket wastegate was that he could raise my boost up more and have it so that it would hold the boost, and not taper off.
ghad
May 25, 2014 02:27 AM
adriano_917
Nov 9, 2013 12:41 PM
blackblaze427
15
Jul 23, 2013 02:21 PM
05blue8
Aug 17, 2009 03:02 PM
otbEVO
Jul 6, 2009 08:11 PM
