How to rebuild an APS BOV
Old Apr 28, 2008 | 05:38 AM
shadow1's Avatar
Anyone know how to disassemble an APS BOV? The 4 allen bolts on the bottom just remove the hose adapter. There are holes in the side of the BOV with what appears to be drilled out bolts. I assume these drilled out bolts hold the piston assembly in place. Anyone know how to dissemble this BOV so I can clean out and regrease the piston assembly?
Old Apr 28, 2008 | 05:41 AM
w3rd's Avatar
I'd like to know this as well. The "working just fine" bov i got from an evom member wont hold anything past 14psi. sounds like a giant queef.
Old Apr 6, 2010 | 06:38 PM
I4UnderPressure's Avatar
Did you guys ever figure this out??? I'd like to know as well.
Old Apr 6, 2010 | 07:04 PM
project_skyline's Avatar
I don't believe you can take it apart.
Old Apr 6, 2010 | 09:19 PM
biggie5252's Avatar
Remove the 4 allen bolts and pop the bottom off. Remove the adjustment screw then stick something in the hole and push the piston out the bottom. Its very simple.
Old Apr 7, 2010 | 06:48 AM
shadow1's Avatar
^^^^exactly. There is an O-ring inside that holds the piston in. I gave up on my APS years ago. I now run the Synchronic. Absolutely the best BOV that I have used.
free ride
10
Nov 11, 2012 04:20 PM
victim619
13
Mar 19, 2012 06:45 PM
Fp3052
Jun 27, 2010 07:53 PM
Mellon Racing
193
May 13, 2010 07:08 PM
bbyevo8u
Feb 3, 2007 05:04 PM
