Need help on removing a broken bolt
Old Jun 5, 2010 | 09:50 PM
Fp3052's Avatar
so i broke the bolt that holds the control arm to the cardle, i believe thats what it is called, but the thing is the broken bolt is about 2 inches in from the surface so its hard to work on . Ive tried an easy out but it broke in the bolt and know i have been drilling the bolt with some left handed drill bits, most of the bolt is gone but stillhavent been able to remove it. Any suggestions on what else i can do? can by any chance i heat the bolt and maybe melt it? Or some how break the remaining part of the bolt? Any suggestions will be appreciated
Old Jun 5, 2010 | 09:56 PM
SLO-EVO's Avatar
Just keep doing what youre doing. tap magic is amazing when it comes to this stuff. keep drilling, and stepping up in bit size... sooner or later, you will be able to get it all out. that is what i do anyways...
Old Jun 5, 2010 | 10:05 PM
Fp3052's Avatar
What if I get the threads what would I do then?
Old Jun 5, 2010 | 10:08 PM
buchnerj's Avatar
I am having this same issue with a broken stud in the hotside. It is a real PITA. Luckily I can remove it and use my drill press. Even if you drill it out to beyond the threads just get a tap and dye kit and tap new threads out and use a new bolt, one size up if necessary.
That is a good suggestion to drill with a smaller bit then work your way up. Too many people make their lives difficult by just trying to use the big drill bit first which causes issues with keeping the hole in the center of where you are drilling, etc.
Old Jun 5, 2010 | 10:14 PM
Bggstin's Avatar
Don't start taking out all the threads. Once you go far enough you should be able to pull the outer shell of the bolt threads out, use some heat if necessary. Once you get it out just run a tap through it to clean up anything you did to the threads in the hole.
Old Jun 5, 2010 | 10:33 PM
goldenEvo's Avatar
You may try a mini die grinder with small bits. Just grind out the bolt and retap the hole. GL.
Old Jun 7, 2010 | 08:48 AM
DarksideZ's Avatar
What he said, and be very patient. Take your time with it.
Old Jun 23, 2010 | 03:48 PM
pablo88's Avatar
Man this happened to me before n i was going through drill bits like crazy unti i got through it. Never want to experiance that agian. Yeah be patient n eventually get there n once it has a thin shell just tap it out with a thread die
Old Jun 23, 2010 | 03:52 PM
meckert's Avatar
Helicoil works well if you f-it up
Old Jun 25, 2010 | 05:48 PM
Fp3052's Avatar
Ok so I got through the bolt but I didn't get it right in the middle and starting to get to the threads a next size bolt I think won't work because the bolt that it comes with barely clears through the control arm. Is there anything else I can do once I i completely drill the bolt out?
Old Jun 26, 2010 | 11:23 AM
Fp3052's Avatar
Any suggestions?
Old Jun 27, 2010 | 07:53 PM
nuggy00's Avatar
if you're drilling out pretty centered, once you starting hitting the threads, you can try to pry the shell of the bolt that's left toward the center of the hole with a punch?
CeliOnce
Mar 15, 2017 05:51 PM
talonkev
Feb 9, 2016 08:24 PM
Sheasta
Feb 3, 2016 08:42 PM
xMCxMRx
May 31, 2015 02:22 PM
webguy330i
Sep 15, 2005 04:38 PM
